Wrong Product Key Message.
Discussion in 'Legacy Windows' started by lj50, 2013/08/21.
  1. 2013/08/21
    lj50 Lifetime Subscription
    lj50 SuperGeek WindowsBBS Team Member Thread Starter
    I installed a different HDD then I performed a custom install from a windows 8 pro 64bit upgrade disc. The drive I used was erased with Drive eRazer Ultra and is a WD7500BPKT. The OS installs fine with product key but when I tried to activate the OS. I get instructed to re-enter the correct product key. Why would it work while installing the OS then not let me Activate or install updates.
    lj50,
  2. 2013/08/22
    "Upgrade" discs generally look for a qualifying OS to be on the drive so that it can upgrade it.
  5. 2013/08/22
    When I install the OS It accepts the product key or it wouldn't allow me to continue. As a test I typed in the wrong product key during installation and the Next button remained greyed out until I typed it correctly then it allowed me to continue.
    lj50,
    Yes, you have a valid product key to do an upgrade. All you need to do is install XP or Vista - register it - then upgrade it.
    That or purchase a Full Install Key Code.
  7. 2013/08/22
    Thank you everyone who responded. Arie's suggestion solved the problem. I kept right clicking on command prompt waiting for a context menu but I did not bother to look at the bottom of the screen so I could click on Run as Administrator. Talk about having tunnel vision.
    lj50,
    #7
  9. 2013/08/22
    Thanks for letting us know that you were able to get your issue resolved. :)
  10. 2013/08/22
    No problem. I appreciate all the help I receive on this forum. The least I can do is mark this thread Resolved. So others aren't wasting their time.
    lj50,
    #9
