Resolved Work Offline Message Pops Up
Discussion in 'Internet Explorer & Microsoft Edge' started by WesternKY, 2009/01/18.
  1. 2009/01/18
    WesternKY Lifetime Subscription
    WesternKY Well-Known Member Thread Starter
    :eek:
    My provider is Bellsouth AT&T DSL. When I click on the IE icon, it will let me try to connect, but the following message comes up: "No connection to the Internet is currently available & to view Internet content that has been saved on your computer, click work offline. Click "try again" to attempt to connect ". When I click "try again" it will connect me to my homepage.
    This is getting kind of old, because it was not doing this before. Can someone please tell me what I must do to stop this message coming up every time I try to get on the internet?
    Thank you in advance.
  2. 2009/01/18
    Hi WesternKY. What Operating System are you running and what version of Internet Explorer? Does this work offline message happen everytime you open IE? Have you tried a different browser? Does the same thing happen? I have seen this message on occcasion but have never seen it happen everytime I start up IE.
    Check out Tools > Internet Options > Connections tab. Make sure Never dial a connection is selected.
    Hello everyone!!!
    Thank you so very much for your replys. I am using IE 7, Windows XP. No, it does not pop up every time I get on IE. Once I click on "retry again" it seems to work find. I can move around as normal. I have found out that if it turn the computer off, and log back in, click on the IE icon, then it usually will pop up.
    It looked into Tools > Internet Options > Connections tab, but "never dial a connection" is no where to be seen.
  6. 2009/01/19
    If you are on ADSL the 'Never dial...' option is set and greyed out - from IE 8, same in 7 .....
    Have you trieda Reset of IE?
    Tools > Internet Options > Advanced
  7. 2009/01/19
    Hello PeteC,
    I will give the Resaet of IE a try. I seen that, but was scared to mess with it thinking that I would really mess something up or lose a bunch of stuff.
  8. 2009/01/19
    PeteC,
    I think the Resaet did the trick!! I tried it a few times and the message did not come up. Thanks a lot to all of you for your advice and time!!
    I am now going to have to get ready to go to Washington DC for our President's inauguration. God Bless.
  9. 2009/01/19
    You're welcome :)
  10. 2009/01/19
    Glad you got your issue resolved. :)
