Wordpad copy and paste
Discussion in 'Legacy Windows' started by lewislewis, 2003/05/29.
  1. 2003/05/29
    lewislewis
    lewislewis Well-Known Member Thread Starter
    Hi
    For some reason I can no longer copy and paste from my browser (ie6) to wordpad. I can copy and paste from notepad to wordpad. Any ideas
    Lewis
  2. 2003/05/30
    brett
    brett Inactive Alumni
    Peculiar! Is it the right-click/paste funtionality which you have lost or the edit/paste functionality? Or both?
    goddez1
    goddez1 Inactive
    If using a customed security setting...
    Have you checked your security tab in IE options and made sure you have enabled copy and paste function?
    If not, try lowering your security setting. Although I'm not sure if this enables copy N paste??? Double check!
  5. 2003/05/31
    lewislewis
    Hi all
    I have checked my security setting's, they are OK.
    I can hilite, copy and paste into notepad from IE6 and then hilite, copy and paste from notepad to wordpad but not directly from IE6 to wordpad. I used to be able to do it though. so something seems to have changed. Thanks for your interest so far.
    All the best
    Lewis
  6. 2003/06/01
    brett
    See my question above.
  7. 2003/06/01
    lewislewis
    Hi Brett
    The problem I have is as described. Hilite (left click) copy (right click) and should be able to paste, as I can browser page to browser page, as I used to be able to Hilite (left click) copy (right click) and paste to Wordpad.
    I hope this clears any misunderstanding
    Lewis
  8. 2003/06/01
    brett
    Highlight some text in IE and select COPY. Open Wordpad and click EDIT - PASTE. Does this work?
