Word 97 problem with stamps.dot and global template
Discussion in 'Other PC Software' started by asp03077, 2006/08/23.
  1. 2006/08/23
    asp03077
    asp03077 Inactive Thread Starter
    I know I have seen this here before but I can't find it. Sorry if this is a repeat!
    If I have one document open and try to open another Word brings up this box, "Word cannot open this document template (C:\Program Files\...\_Stamps.Dot)"
    So I hit OK
    Then another box comes up
    "Word cannot open the existing" " (with some funky character I can't replicate)
    So then I X out of that box and it asks me
    "Do you want to replace the existing Normal "
    I hit No and it goes to this box
    "Save as--Save in--Templates---File name normal "
    It then goes to the document again and I X out of that and the next box says
    "Changes have been made that affect the global template, Normal. Do you want to save those changes? "
    I just hit no and I finally get out of this mess!
    Do I have 2 problems here? I have other Word programs on other computers and never came across this problem so I am not sure if it is typical for this version or not. I am not the one who set this up, I came in after the fact!
    Does someone have the answer to my prayers...I can get around it but it is sooo annoying, I'd love for it to stop!
    Thanks so much!!!:)
    C*
  2. 2006/08/23
    You sure do find the oddball errors :D
    Googling brings up 2 hits from MS - both in Italian :)confused: ) the translation of which is here ....
    http://translate.google.com/transla...rd+97&hl=en&lr=&rls=GGLG,GGLG:2006-15,GGLG:en
    If you can follow the computer translation there seems to be a workaround. Looks like it is a conflict with a mail franking program.
    Your other options to fix are .....
    Close Word and search for Normal.dot and rename it say Normalold.dot. Word will recreate normal.dot next time it is opened.
    or
    Try a repair or Word - Help > Detect and Repair.
    asp03077
    Hello,
    Thanks for the advice. I deleted stamps.dot, so far so good. I'm still getting an odd error but it is a quick one to just X out of. (it says "Word cannot open the existing "with a funky backwards L character up by the quotations...??) Hopefully there will be no bad reprecussions from this delete. We'll see.
    As for the normal, it just says normal, not normal.dot. But I can try renaming and seeing what that does.
    Thanks again!
    C*
  5. 2006/08/24
    asp03077
    Well, I still have the "normal" problem. I am ready to give up. Why does it say I am putting changes to the global template? Do you think it is because the person before me used the template and I am changing things without even realizing it? I am so confused! Like I said, my other computer does not do this and I am the only user so I have been just going along doing my stuff and it never told me I am trying to change a template or whatever!
    C*
  6. 2006/08/24
    The reason that you are seeing Normal as opposed to Normal.dot is because the computer has the default settings in Tools > Folder Options > View - you will find that 'Hide extensions for known file types' is checked - uncheck it if you want to see all file extensions.
    I suggest you accept the 'changes' made to normal .dot and see what happens - you can always get back to square one by renaming normal.dot as before.
    Otherwise try the repair of Word.
  7. 2006/08/24
    raingirlIT
    raingirlIT Inactive
    If I recall you have office 97 right? That is no longer supported as far as I can tell by microsoft (no more updates). I had this problem (I run 97 as well) at work, and the only fix to it was to go to microsoft's page and install all the available updates.
    Here is the link:
    http://office.microsoft.com/en-au/officeupdate/CD010224961033.aspx
    I don't recall which update it was, but problem SR1 or SR2.
