Resolved Won't recognize external hard drive.
Discussion in 'PC Hardware' started by Fauxqui, 2010/05/11.
  1. 2010/05/11
    Fauxqui
    Fauxqui Well-Known Member Thread Starter
    I have an Iomega external hard drive (350 mb) that I use with my laptop (XP Pro). All was well until about a week ago when the laptop stopped recognizing the drive. It saw it (F:) but couldn't open it.
    I rebooted and the laptop did a scan of the drive and apparently fixed some bad sectors. All was well until yesterday when it started to do the same thing. When I reboot now however it doesn't do a scan.
    How do i get itto scan and repair?
  2. 2010/05/11
    Start > Run > type in cmd > Enter
    At the flashing cursor type cd\ > Enter - this takes you to the root of C:\
    At the flashing cursor type F: > Enter - this takes you to your F:\ drive - if it is recognised
    At the flashing cursor type chkdsk /r > Enter Enter
    A scan should start.
    It would seem to me that the drive is dying and if you manage to get into it again copy off all your data pronto!
    anands
    anands Inactive
    I agree with Pete as it seems to be dying, better to back up the contents in it.
    I think you are connecting via USB/Firewire! you may ask a H/W people to remove the external casing and try to connect the HDD as secondary HDD in your PC.
  5. 2010/05/13
    Fauxqui
    Thanks guys, I managed yto get the iomega drive to respond and copy all the info to a new back up drive. Now to delete 10,000 duplicate iTunes!
  6. 2010/05/13
    Good news :)
    Please mark this thread as 'Resolved', see .....
