Resolved WMI Usage running at 60% Spiking to 100%
Discussion in 'Windows 8' started by EdieinDeep, 2013/05/13.
  1. 2013/05/13
    EdieinDeep
    EdieinDeep Inactive Thread Starter
    76
    Computer Experience:
    intermediate
    My WMI Provider Host runs at about 60% CPU usage and will spike to 100% when I do things like opening Google Chrome. I find I have trouble running games (nothing fancy game wise just some MSN games) I usually have nothing else running during these events.
    Can this be right? :confused: Any thoughts?
  2. 2013/05/13
    1,093
    Walnut Creek, California, United States
    Intermediate+
    Hi EdieinDeep, Welcome to Windowsbbs! :)
    The Windows Management Instrumentation Service runs under one of the svchost processes along with a bunch of other Windows Services. Are you sure that there are no other processes that are causing the CPU usage to spike to 100%?
    Download and run Process Explorer and see if you can identify if there are other Windows Services or processes that are causing your CPU usage to spike.
    Also one other thing you can try it is to Perform a clean boot to troubleshoot a problem in Windows 8, Windows 7, or Windows Vista and see if you can rule out other 3rd party programs causing a problem.
    Having the WMI service using 60%-100% of the CPU is not normal and that behavior definitely should not be happening.
    EdieinDeep likes this.
    EdieinDeep
    76
    intermediate
    Thank you Terminator. I have downloaded Process Explorer and I see that the only big ticket items are System Idle @ 56% and WMI @ 35%... bouncing around of course. I will read about clean boot and give that a try.
  5. 2013/05/14
    1,093
    Since you have a HP product, a clean boot would probably give you the answer.
    Do you have the HP Wireless Assistant (HPWA) installed? If so, uninstall it, it doesn't serve any purpose anyway.
  6. 2013/05/14
    EdieinDeep
    76
    intermediate
    Good Morning, I did the clean boot and I am not having any trouble now. In fact I can't even see a line item for WMA in Process Explorer. However I am not sure I understand what was eliminated in the clean boot that gave me this outcome. BTW HPWA was not installed.
    Thank you both.
  7. 2013/05/14
    1,093
    Go to the services manager to see which system components depend on WMI. Double click the Windows Management Instrumentation service, then select the Dependencies tab and note what is listed.
  8. 2013/05/14
    EdieinDeep
    76
    intermediate
    These are the dependencies:
    • Internet connection sharing
    • IP Helper
    • Security Center
  9. 2013/05/14
    1,093
    Intermediate+
    In Task Manager under the Startup tab you will have to re-enable each startup item one at a time until you can determine which program is causing the CPU usage to spike. The default Windows services are not causing the problem, its a 3rd party program that is installed that is causing the WMI service to spike for some reason.
  10. 2013/05/14
    EdieinDeep
    76
    intermediate
    Thank you Evan.
  11. 2013/05/15
    SpywareDr
    1,093
    Maryland, USA
    Experienced
  12. 2013/05/15
    EdieinDeep
    76
    intermediate
    I've enabled all but one Startup item and all totaled CPU was at about 12%. I noted that the line item for WMI was not appearing in processes screen. There was one file left in Startup called "NA" which looked suspicious. When I enabled it everything spiked up to about 60% and Malwarebytes became very busy. I immediately disabled it again. There are no properties associated with it and it does not disclose the file location. How do I safely remove it?
  13. 2013/05/15
    1,093
    I wouldn't. The problem is not a corrupted WMI service.
  14. 2013/05/15
    1,093
    Read this post, then post the requested log(s) in the Malware and Virus Removal forum.
  15. 2013/05/15
    1,093
    Intermediate+
    Yeah that sounds like it could be a malware infection of some sort.
    Create a new thread in the Malware and Virus Removal Forum as Arie has instructed with a link back to this thread so broni has more information about your problem.
  16. 2013/06/08
    1,093
  17. 2013/06/08
    1,093
    Intermediate+
    Perfect. :cool:
