wldcore.dll is missing
Discussion in 'Windows 10' started by lynn1102, 2016/11/10.
  1. 2016/11/10
    lynn1102
    lynn1102 Well-Known Member Thread Starter
    For the past week, I get this message when I click on a "contact me" link on most sites. How do I fix it?
  2. 2016/11/10
    lynn1102
    Thanks for that info on the.dll's. I give them a shot and let you know. I did print out the instructions.
  5. 2016/11/11
    lynn1102
    lynn1102
    I would like to add a bit more information to this post. None of the solutions solved the problem.
    My Live Mail works fine 99% of the time. With this DLL message popping up sometimes, I just want to make sure it doesn't cause any other problems. When I'm on a web site and I click on an e-mail link or a "contact" link, this is when the message pops up. I can take that link and either type it or paste it into my address bar and it works fine.
    I did a search for wldcore.dll and found 3 instances of it. One in Live Mail Contacts, one in Live Mail Messenger, and one in Live Mail Shared. All three files are 79.1k and dated 3/31/14. wldlog.dll is also in all three folders.
    I ran sfc and no problems found. I checked the registry and nothing unusual there.
    I can work with this problem, but should I be concerned about it causing other problems?
  7. 2016/12/21
    I suspect the problem amy not be Live Mail but may be the Web browser. Which browser do you use and what version?
