Resolved WLAN Autocfg service not starting
Discussion in 'Networking (Hardware & Software)' started by atlcr, 2011/12/01.
  1. 2011/12/01
    atlcr
    atlcr Inactive Thread Starter
    Hello,
    I have a computer running Windows Vista that is unable to see any wireless networks. The wired internet is working fine. I have Avast free running as the anti-virus and have done scans with it, malwarebytes, and superantispyware.
    This is what else I have tried so far:
    -tried to manually start service and have it set to automatic
    -ran sfc /scannow - it fixed some problems but could not fix others
    -checked event viewer and see an error code for the WLAN service (3222070536)
    Not sure if it is still a lingering virus or if the problem relates to the files that sfc could not repair - or something else?
    Any help is greatly appreciated. I'd like to avoid reinstalling Vista if possible.
    Thanks!
  2. 2011/12/01
    atlcr
    Ok, I figured it out. I scanned through the BBS.log file generated by sfc and found one file in the L2schemas directory under Windows that was not fixable. I took a copy of that file from a working Vista machine and replaced it. After a reboot I was able to see networks and connect wirelessly no problem. :)
    Hopefully this helps someone out down the line. I had literally tried everything up until this fix.
    Good job, and thanks for posting your solution.
  5. 2011/12/01
    It is considered courteous to post a reply if you have been able to resolve your problem, or received an answer to your question. If you were given multiple suggestions/solutions, it is also helpful if you would list the solution that worked for you.
    Once you have posted those details, when still looking at your thread, near the top of your thread you'll see Thread Tools. Click the down arrow to expand the drop down menu, at the bottom of it you'll see Mark this thread as solved. Click on it to mark your thread as solved.
    If later you find that the problem has returned, and you had previously marked your thread as solved, follow the steps above. Instead 'Mark this thread as solved' you will see that in this case Mark this thread as unsolved is listed.
    Please read the User Guide for more information.
