Wireless working weird
Discussion in 'Networking (Hardware & Software)' started by fball, 2008/06/08.
  1. 2008/06/08
    fball
    fball Inactive Thread Starter
    Hello once again...
    This time i have quite weird problem.The thing is that my wireless is working only when signal is low (10-15%) and that sometimes causes me being disconnected.
    i dont understand why on 60-70% my wireless isnt working,only on low signal.
    does anyone knows what could be problem?
    Thanks,
    Dean
  2. 2008/06/09
    ReggieB
    ReggieB Inactive Alumni
    A guess - could it be that you are getting interference from a neighbour's wireless system and poor signal from your own. What you are seeing as good signal is the neighbours wireless network that you can't connect to. When they switch their system off, you see your own signal, but that is weak.
    Try changing the wireless channel (a router setting) and test close to the wireless router.
    fball
    But the weird thing is that i was connected to that AP for over 2 years now and everything was working great.
    but now its working only when signal is low...
  5. 2008/06/09
    ReggieB
    I think interference or hardware failure are your most likely culprits. Try changing the channel first.
  6. 2008/06/09
    DDTSmokey
    DDTSmokey Inactive
    look for some changes in the networking structure like added routers or AP's.
  7. 2008/06/11
    fball
    ok its working now...
    we rebooted router and its ok now.
    thanks for help guys!
  8. 2008/06/11
    DDTSmokey
    DDTSmokey Inactive
    glad to hear!!!:)
