Resolved wireless won't connect
Discussion in 'Networking (Hardware & Software)' started by rgn, 2012/12/05.
  1. 2012/12/05
    rgn
    rgn Inactive Thread Starter
    I have two laptops, one win 7, one xp. The xp one won't connect to the wireless. The win 7 connects.
    In the "Network Connections ". the wireless network connection has a red cross, and says Not Connected. When I right click it, then open Properties. It shows disabled. It should show enable! It doesn't, it only shows disable. I click on it and it only puts on a Red cross.
    Any help on how to enable this wireless network on my xp laptop? It's been working great up to now.
    I'm connected with a Ethernet cable to the modum.
    The xp laptop is a Dell 1500 Vostro.
    rgn,
  2. 2012/12/05
    Control Panel > Network Connections > right click the wifi icon and select enable.
    SpywareDr
  5. 2012/12/06
    rgn
    I tryied that. It has only disable in the drop down. The icon shows not connected.
    rgn,
    rgn
    The light is on. I hover over the wireess icon in the tray, and it says, not connected/not available.
    rgn,
    #5
  7. 2012/12/06
    rgn
    wireless
    Found the problem.
    The WLAN card untility box, need to uncheck the "let this tool manage your wireless networks ".
    Cox Tech help find this bugger.
    rgn,
    #6
  8. 2012/12/06
    Where did you find that at?
  9. 2012/12/06
    catilley1092
    catilley1092 Well-Known Member
  10. 2012/12/06
    OK. Have a grandson that I changed out a bad Modem/Router and now his Vista laptop won't connect. All the other wireless laptops, phones, IPAD and IPOD do. Anything wired or wireless will connect but his laptop. It worked before. I need to start a thread on this when I have time to fool with it more.
  11. 2012/12/07
    That tool may be set to load at boot & it's not needed. Use Start > Run > msconfig > Startup tab and if listed, prevent it from loading at boot.
