Wireless networking a NT 4.0 pc to a W98 pc
Discussion in 'Networking (Hardware & Software)' started by wdc202, 2003/08/10.
  1. 2003/08/10
    wdc202
    wdc202 Inactive Thread Starter
    Can anyone please recommend the wireless networking products I need to install to network my Dell laptop (Model PPL; CP M233ST with Windows NT 4.0 WorkStation, Service Pack 6) to the cable modem I now have on my IBM desktop (with Windows 98). Thanks for your help. ... wdc
  2. 2003/08/11
    Tap-Out
    Tap-Out Inactive
    If the Win98 machine is always on, it may be cheaper just buying a wireless network card for both the desktop and laptop and using ICS on the win98 machine. If it's not always on I would probably recommend a Linksys wireless router. The router is a little more expensive than the two wireless card option.
    wdc202
    Thanks. I had never heard of ICS; will look into it. .... wdc
  5. 2003/08/11
    Tap-Out
    Tap-Out Inactive
    What ICS stands for is Internet Connection Sharing
    What this will do is essentially the same as a router, except with a little less flexabality (sp?)
    You add the service from your windows 98 cd, from the network neighborhood properties.
    I do believe www.techfest.com has a tutorial or two on it, but as you said, you may want to look further into it.
