Wireless Network Adaptor doesn't connect after sleep
Discussion in 'Windows 7' started by boutells, 2010/06/01.
  1. 2010/06/01
    boutells
    boutells Well-Known Member Thread Starter
    I recently upgraded to Windows 7 from Vista. Since that time, my Belkin Wireless Network Adaptor intermittently doesn't activate after the computer wakes from sleep. If I unplug it and plug it back in, the computer then finds it and it works normally, until the next time.
    It always worked when I was using Vista.
    It is a minor annoyance but does anyone have a solution?
    It does not seem to be the USB port as I have tried it in several with the same result. It is now going through a hub and all the other connections in the hub work normally.
    I have uninstalled, downloaded and reinstalled the driver and that hasn't helped.
  2. 2010/06/01
    Try this possible solution .....
    Device Manager > USB Root Hubs - right click on each > Properties > Power Management and ensure that 'Allow the computer to turn off .....' is unchecked. I think the default is checked.
    boutells
    Ok. Will give that atry; Thanks.
  5. 2010/06/03
    boutells
    Further on this, that didn't work.
    When O went into the Device Manager and clicked on Properties for the adaptor, there was the following message.
    "Windows has stopped this device because it has reported problems. (Code 43) "
    Anyone know what that means and how to deal with it?
  6. 2010/06/03
    According to MS ......
    Difficult to say if it is the USB controllers - which you say function OK otherwise or the card driver - more likely.
    Did you get the driver direct from Belkin?
