Wireless G card and Wireless N router?
Discussion in 'Networking (Hardware & Software)' started by gobears20, 2009/02/06.
  1. 2009/02/06
    gobears20
    gobears20 Inactive Thread Starter
    I have a Dell Inspiron 9200 with a wireless G card installed. If I bought a Linksys Wireless N router, would my Dell connect to it?
  2. 2009/02/06
    wildfire
    wildfire Getting Old
    It should but everything on the network will work using g not n.
    gobears20
    Thanks.
    When you say everything on the network, do you mean things like a wirless printer and things like that?
  5. 2009/02/06
    wildfire
    Yes any wireless device will revert to the lowest used standard. Obviously this won't affect wired devices.
  6. 2009/02/07
    aweston
    aweston Banned
    You can do it, but I've seen wireless G cards get in trouble with wireless N routers sending mixed mode..
    Frankly, wireless N is a waste of time. It's not standardized, it's *highly* overrated and realistically speaking, a good wireless G router will stomp on it for range. A Linksys pumps out about 27mW of power with 2dB antennas. The multiple antenna array enable it to utilize certain obstructions to it's advantage.
    However, an Engenius ESR-1220 puts out 100mW of power and uses a 2dB. It will blast a signal significantly further than wireless N will. Of course it has a detachable antenna. Put an 8dB omni-directional on it and it will completely devastate any of the competition without even breaking a sweat.
