WinXP won't start now
Discussion in 'Windows XP' started by Norseman, 2002/09/22.
  1. 2002/09/22
    Norseman
    Norseman Inactive Thread Starter
    Help! After loading WinXP yesterday on my Toshiba laptop (3000-S353), I had everything running ok - at least as far as the OS is concerned. But then I tried installing some different video card drivers and the system locked up, so I had to shut it down. Now it won't start back up and go into Windows... once I turn it on, all I get is a black screen. I've tried everything, holding down the key while starting back up, F8, etc. I hadn't made a boot disk for it yet since XP doesn't run on DOS anyway... would that help me in this situation if I had? So what does a WinXP user do in a situation like this? I'm real frustrated because I was hoping to bring this laptop with me on an important trip this week. Please help me, any advice would be much appreciated!
  2. 2002/09/22
    Abraxas
    Abraxas Inactive
    Is that all you get, from the very beginning, is a black screen, or does the blank only appear after POST and after XP attempts to start?
    If you get no video whatsoever, the incorrect driver may have fried the video card.
    ningaming
    ningaming Inactive
    yeah i've fried my video card too many times...sigh
    see if that vid. card works in another machine if u have it available
  5. 2002/09/22
    Norseman
    It's black all the way... nothing else I'm afraid.
    You gotta be kidding me... I never heard of the wrong driver frying a video card. That'll really **** if it's true. We Toshiba owners are trying thois all the time since Toshiba does absoulutely nothing to upgrade their drivers...
    NEVER buy a Toshiba!
  6. 2002/09/22
    Abraxas
    Abraxas Inactive
    That doesn't sound good, Norseman. If it is black all the way, then XP hasn't started and the problem is in hardware. Sorry.
  7. 2002/09/23
    Rancher
    Rancher Inactive
    vga
    I don't it's cooked either. You said after xp was installed things worked until you tried installing new drivers for the card rite?
    Reboot & press f8 on the posting until you get the boot menu. Now select start in vga mode [enter] this brings you to vanila 16 colors & winxp will say "do you want the video adjusted for best performance?" select YES:)
  8. 2002/09/23
    Norseman
    Actually, in my original post I mention already trying F8... nothing happens.
