WinXP Fujitsu WLAN problem
Discussion in 'Windows XP' started by laasunde, 2005/10/18.
  1. 2005/10/18
    laasunde
    laasunde Inactive Thread Starter
    Hi,
    I've recently reinstalled my fujitsu simens laptop with Windows XP (Home edition) but now my builtin wifi card doesn't work. Using sp2 and all the latest drivers from fujitsu simens homepage.
    The wifi card is enabled in device manager.
    Have tryed the laptop on several wireless networks without any luck.
    Appreciate any advice ?
  2. 2005/10/18
    Scott Smith
    Scott Smith Inactive Alumni
    What utility are you using to manage the card?
    Windows?
    See the atachment.
    skeet6961
    skeet6961 Inactive
    define 'doesn't work' exactly.
    is it present and 'ok' in devicemanger?
    what errors, if any, do u receive?
    if no errors, what specfic settings do u have currently and what are trying to connect to?
  5. 2005/10/19
    laasunde
    The device is ok in device manager.
    Tryed both letting windows control the card and the utility that came with the card.
    No error messages.
    The wifi card just doesn't find any network even when laptop is 2 inches away from a wireless router that works for both of my flat-mates.
  6. 2005/10/19
    Scott Smith
    Is there a switch or a function key somewhere to turn on the WIFI antenna?
  7. 2005/10/19
    skeet6961
    skeet6961 Inactive
    what is the security settings on that router? u MUST meet those if they're set. check the router doesn't have MAC filtering on. if it does, add u'r MAC address.
    assuming that the router is compatible on signal here too. eg - u'r doing G and the router does G too.
