WinXp address toolbar in taskbar problem and/or Iexplore problem
Discussion in 'Windows XP' started by pccoach, 2005/01/30.
  1. 2005/01/30
    pccoach Lifetime Subscription
    pccoach Well-Known Member Thread Starter
    In the WinXP when I try to access the Internet by typing in a URL into the the address toolbar in the taskbar I get an error message to try using the search feature through the start menu. I'm guessing the problem isn't really with the toolbar but with iexplore becaue if i already have an Internet window open then accessing a URL from the taskbar address toolbar will work. any ideas on what to do? thank you... :confused:
  2. 2005/01/30
    Take a look here
    If no help there run System File Checker - first stage in a Repair of IE/OE
    thanks...will try solutions and post on my success. thanks again.
  5. 2005/02/04
    so far neither solution has worked...have uninstalled and reinstalled IExplorer. that didn't work either. may just cut my losses and reinstall xp...thanks!
