Window Xp Autorun Cd Feature Not Able To Enable
Discussion in 'Windows XP' started by panchal, 2002/05/21.
  1. 2002/05/21
    panchal
    panchal Inactive Thread Starter
    how to enable autorun feature for running CD on inserting in dvd drive] IN window xp Had tried no value data 95 00 00 00 in regedit
  2. 2002/05/22
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\CDRom
    Change to value of 'Autorun', or create a new DWORD value if it doesn't exist: (0=disable, 1=enable)
    panchal
    feed back for autorun enabling
    Had tried tip to modify regedit but is not working , on R.H.S noted autorun Dword value 1 , also noted autorunalways disable folder showing different make of cdrom is it required to modify this ?
  5. 2002/05/23
    If your PC thinks you have a different brand of CD drive than you really have, I would expect problems.
    Sorry but can't figure out a meaning for "R.H.S noted autorun" or "autorun always disable folder ".
    First thing I would try is to get the latest drivers for the device then remove it (from safe mode) and see how a reinstall works using the new drivers.
    Also - is your CD on the list of hardware XP likes?
    panchal
    Thanks for your reply and effort , had also mailed u seperately, R.H.S means right hand side of regedit deskscreen which appears when I click link sugggested by u of CDROM .
    MY dvdrom is pioneer and is on list . but I also see autorundisable always on right clicking and choosing modify it shows all makes of dvd/cd rom drives from which one of them is mine .following appears
    default reg-sz valu data 1
    Autorun reg-dwd 0x00000001(1)
    Autorun always disable NEC, MBR-7NEC,PIONEER etc....
    start
    tag
    type
    can above help u to advise remedy
    Once again many thanks for your efforts Sir,
    Panchal
  7. 2002/05/24
    Thanks for the clarifications.
    At this point, I think an email to tech support for the device would be in order. They may have done something strange.
    #6
