WIn98 restarting problem
Discussion in 'Legacy Windows' started by arun123, 2003/02/09.
  1. 2003/02/09
    arun123
    arun123 Inactive Thread Starter
    hi,
    I am having a bit of a strange problem here.The PC is a AMDK6-500 with 64 mb sdram and a PCI graphics card.The PC keeps workin normally but unexpectedly keeps restarting when the user is working . Does anyone supect the graphics card? Is there any other reason.?
  2. 2003/02/09
    merlin
    merlin Inactive
    Athlons are known for stability issues caused by inadequate cooling... Make sure your CPU fan is suitable
    Most newer motherboards allow you to monitor the CPU temp, fan speeds, etc. And some will shutdown the computer if the CPU reaches a certain temperature..
    You should read the manual for your motherboard and make use of these features and browse around your BIOS setting as well.
    Apart from the overheating issue, other hardware components may be cause instability issues do to conflicts, etc. - check your event log for any alerts
    Finally, there may be certain software running which will cause the computer to reboot to due an error with the software
    Hope this helps! good luck
