Win7 and no sound
Discussion in 'Windows 7' started by tryan58, 2009/09/01.
  1. 2009/09/01
    tryan58
    tryan58 Inactive Thread Starter
    After installing Win7, I get a message "no sound device installed" and thus no sound. Any suggestions?
  2. 2009/09/01
    Welcome to WindowsBBS;)
    Does your computer have a sound card;)
    Did your sound card come with a cd with drivers on it?
    Athlonite
    Athlonite Inactive
    erm can you please fill your computer spec in your profile as it really helps when trying diagnose a problem if we know what your using
    now what OS were you using befor seven did you have sound available then if so then what was called
  5. 2009/09/03
    Zykan
    Zykan Inactive
    When i ran Windows 7 Advisor it stated that i would have to go to the MS site and update the sound card driver for it to work in Win7 - Maybe you should try this unless already done so.
  6. 2009/09/03
    Athlonite
    Athlonite Inactive
    thats only good if windows update actually has a driver and from the looks of things it doesn't otherwise it would have install a driver a soon as he connected to the net
