win XP, problem in viewing hidden files
Discussion in 'Windows XP' started by imamit76, 2008/02/27.
  1. 2008/02/27
    imamit76
    imamit76 Inactive Thread Starter
    Hi all,
    I want to see hidden files in my PC.
    I know how to see hidden files....in the drive, Tool>Folder options>view and click on "show hidden files and folder ".
    After doing OK, if i go back to the option again, "do not show hidden files and folders" is checked. Means it is not allowing me to select the option "show hidden files and folders "
    Thanking you in advance....
    Amit
  2. 2008/02/27
    noahdfear
    noahdfear Inactive
    Sounds as though you account doesn't have Administrative privledges. Is the account a Limited User account?
    imamit76
    I tried with Administrative login. Sorry i forgot to mention it....
  5. 2008/02/28
    p spino
    p spino Inactive
    hi
    did you click apply before hitting ok.
  6. 2008/02/28
    surferdude2
    surferdude2 Inactive
    Possibly a Registry key is corrupt. Click HERE and select RUN when asked. Allow the file to add the correct values to your Registry. Check for effect and report back please. There are other possibilities but they are not the norm.
