Win XP Power Options Icon
Discussion in 'Windows XP' started by D.Matura, 2007/06/20.
  1. 2007/06/20
    D.Matura
    D.Matura Inactive Thread Starter
    Win XP-SvcPak-2
    The power options icon in tray "by clock" keeps disappearing on my laptop even though it is checked to "always show ". If I un-check it and then re-check it, it might work fer a bit and then disappears again. Any ideas! thanks Den............
  2. 2007/06/20
    Do you have "hide inactive icons" enabled in the taskbar properties?
    D.Matura
    Win:XP-svc-pak2/power options icon
    No I don't......Den.........
  5. 2007/06/21
    PaalN
    PaalN Inactive
    So where have you checked "always show" ? in taskbar options, or power options in control panel?
  6. 2007/06/21
    D.Matura
    Win:XP-svcpac-2 Power Options Icon
    Power Options in control panel is checked and taskbar option to hide inactive icons is unchecked.....Den...................
