Win XP Microphone problem
Discussion in 'Windows XP' started by beejay, 2009/01/26.
  1. 2009/01/26
    beejay
    beejay Inactive Thread Starter
    I recently upgraded from Win 2k to Win XP using an Win XP upgrade CD. All seems to have upgraded correctly apart from 1 thing - my microphone no longer is capable of recording sounds.
    When I try to use Start - programs - accessories - entertainment - sound recorder, to test the microphone, and try the red button to record, I get a message :" Another application is recording audio. Stop recording with this other application and then try to record with sound recorder again. "
    Have you any suggestions what this means? I can't think of any other recording device in use.
    How can I solve this problem?
  2. 2009/01/26
    Hi,
    Go to Start > Control Panel > Sound And Audio Devices, select the Audio tab and make sure that under Default device for Sound Recording the proper device is selected.
    beejay
    Thanks Arie.
    Under Audio and Sound Recording tabs, both show Playback and Recording entries as Modem #0 Line Playback and Modem #0 Line Record respectively.
    Not sure what this means.
    However, under Voice tab, when I click on test hardware -> wizard, I get a message to say "Your sound hardware cannot play sounds! "
    Can you explain and help further?
  5. 2009/01/27
    It most likely means you have to find a Windos XP driver for your sound card.
    beejay
    Yep. That was the first thing I thought of doing. I have downloaded and installed the drivers and still have no microphone working.
    In fact, I do not have as much "sound" as I thought either.
    I can play a music CD but only by using Real Player or via Start-programs-accessories-entertainment-CD player. The music will NOT play using Windows Media Player. Also, BBC iplayer plays the video but does not produce sound.
    How do I get the sound card to show up as a selected option within sound and audio devices in Control Panel (see earlier post)?
  7. 2009/01/27
    What shows in your Device Manager under Sound, video and game controllers?
  8. 2009/01/27
    beejay
    Device Manager shows :
    Audio Codecs
    C-Media PCI audio device
    Legacy audio drivers
    Legacy video capture drivers
    Media control devices
    Unimodem Half-duplex audio device
    Video codecs
  9. 2009/01/27
    I would try:
    • Uninstall the sound devices from Device Manager, reboot & re-detect the sound device
    • Update your computers chip-set driver
  10. 2009/01/27
    beejay
    Thanks Arie.
    I have now done as you suggested. On reboot, the PC reported that it had found new (audio) hardware and I updated the drivers for ALL 8 pieces of sound & audio hardware within device manager.
    No change, I'm afraid. Windows detects and identifies the sound card correctly but does not put it into the correct place as default device for sound recording. It does not even offer it as an option from the drop down menu.
    Any other suggestions?
  11. 2009/01/27
    No, sorry (except for my other suggestion above: "Update your computers chip-set driver ")
  12. 2009/01/27
    beejay
    Sorry. I should have told you that I had done that too.
    And I should have mentioned that Device Manager told me that all devices in sound and audio were working properly. I beg to differ!
  13. 2009/01/28
    linbrad99
    linbrad99 Inactive
    Perhaps the mic cable has a short in it try a different microphone.
  15. 2009/01/28
    beejay
    Microphone works fine in another PC.
  16. 2009/01/31
    beejay
    After all these trials and tribulations I find from other experts that a windows "upgrade" rather than a clean install is very often prone to have something break. Upgrades are therefore NOT recommended even though they are sold as if there are no real problems. I have therefore given up and done a clean install of XP.
    All working fine now.
  17. 2009/02/02
    Yea, it's been too long ago I encountered a Win2K > WinXP "upgrade ", but that has always been the advise we gave to people back in the days that most were migrating from Win2K > XP.
    Glad you got it fixed.
