Resolved will my dell c540 LT shut down when to hot
Discussion in 'Mobile Devices' started by gary7, 2011/03/29.
  1. 2011/03/29
    gary7
    gary7 Well-Known Member Thread Starter
    I was given a old Dell c540, it works great, but need to know if I leave it on to long in a confined space using the ac wall adapter, heat I know, will build up, could this potentially damaging components in side the computer, or is there a built in thermal switch to shut it down to avoid this....
  2. 2011/03/29
    lj50 Lifetime Subscription
    If you are going to constantly run the laptop wirh the AC/Adapter. You should remove the battery from the laptop.
    lj50,
    In a confined space, it will over heat and shut down possibly causing major damage. I never put my laptop directly on my lap. I have a laptop holder that I use. Most laptops have the fans on the bottom and they are usually right where it sits on you leg. I agree about removing the battery also.
  5. 2011/03/30
    gary7
    Ok, thanks, I though some sort of safety device in side the laptop would shut it down. I was trying to get get rid of bed bugs, see other post.
  6. 2011/03/30
    If you leave your laptop switched on in a confined space it will get hot only if you are using it. Most laptops will shut down the screen after a few minutes when not used.
    It may also be set to hibernate after preset time - will not get hot.
    I would suggest you stay with your original Post re Bed Bugs removal. Neil.
