widows xp home problems with computor
Discussion in 'Windows XP' started by wayne jones, 2010/11/16.
  1. 2010/11/16
    wayne jones
    wayne jones Inactive Thread Starter
    Hi
    untill the last couple of weeks my computor has been running fine.
    System Specifications
    Subsystem Description Specification
    Browser MSIE 8.0
    System OS Windows XP Home SP3
    System OS Install Date 1/1/2003 1:11:17 AM
    System Make eveshamvale
    System Model MS-6743
    System Serial Number
    Main Board Make eveshamvale
    Main Board Model MS-6743
    Main Board Version Ver1.1A
    Main Board BIOS Phoenix Technologies, LTD Ver1.1A IntelR - 42302e31 20040917
    Processor Description Intel Pentium 4
    Number of Processors 1
    Processor Clock Speed 3200 Mhz
    Graphics Description ATI Radeon HD 3850 AGP
    Memory Installed 2048 MBs
    Memory Slots 4 slots
    Memory Configuration 512+512+512+512;DIMM SDRAM Synchronous
    Drive Name (C) New Volume
    Drive Size (C) 190779 MBs
    Drive Format (C) NTFS
    Drive Name (F)
    Drive Size (F) 32240 MBs
    Drive Format (F) NTFS
    Drive Name (G)
    Drive Size (G) 30890 MBs
    Drive Format (G) NTFS
    Drive Name (H) User Data
    Drive Size (H) 45425 MBs
    Drive Format (H) NTFS
    CD-RW Model SONY CD-RW CRX320E
    CD-RW Read Speed 22160 KB/sec (126X)
    CD-RW Write Speed 9173 KB/sec (126X)
    Monitor Model HSD 245311
    Monitor Resolution 1600 x 1200 pixels
    Monitor Screen Size 15.6 x 9.8 inches
    18.4 inches (diagonal)
    Monitor Manufacture Date December 2006
    Monitor Serial Number 5527
    this last week or so i have been having the following problems
    1. The computor will load up and then either freeze straight away or freeze after 5 or so minutes.
    2.When starting computor after crash i press the power button and the computor doesnt respond for 20-30 seconds after which it all comes back to life and starts up.
    3.The computor has unexpectedly shut down during use twice over last couple of weeks.
    i have run Malware bytes,advanced windows care and avast anti virus none have shown any issues.
    i have also followed advice from a similar thread and run regcleaner and again this gave no issues.
    the only thing i can think of that has changed at a simalar time was my trial copy of microsoft works 2010 has expired ,i have reverted to the 2003 version ,i can not delete the files left behind by 2010(they dont show up in the uninstaller list)
  2. 2010/11/16
    Will the pc eventfully run OK or is five minutes the max that it will run?
    If it only runs five minutes "“ it could be a heat issue. Is the case full of dust bunnies?
    wayne jones
    hi it will eventually stay on once it is up and running although it has shut down twice after running for long periods,i thought it might be a heat problem ,so have ordered an extra fan,
    when i checked my processor usage in the windows task manager i noticed that "wuauclt.exe" was using 122,692 memory i dont know if this has any cause or
    effect!
  5. 2010/11/16
    markmadras
    markmadras Banned
    The file wuauclt.exe is responsible for checking with the Microsoft web site for operating system updates. It should only be found in the windows/system32 folder, if it appears in any other location it will be a virus that your scanner has not been able to locate. Do a manual search for the file to check on its location or locations. If you find it in other locations then you have an infection and you should go to the Malware and Virus forum, follow the instructions and post the logs as requested.
    Fitting additional fans may deal with overheating but that will not rectify the cause. Your system has been working OK until recently so the cause should be established first before taking any other action. If it is overheating then it will be due to a faulty fan, bad contact between the heatsink and the CPU or dirt clogging the heatsink or the PSU.
    Check that the PSU and the CPU heatsink are completely clean and that the CPU heatsink is not loose. Make sure the fans all run freely at start up.
    I have not been able to check how much memory wuauclt.exe should be using but that figure seems quite high, you could try to disable it and see if the crashes continue.
    wayne jones likes this.
