Resolved Why does customize desktop icon keep changing?
Discussion in 'Windows XP' started by robls99, 2013/08/09.
  1. 2013/08/09
    robls99 Lifetime Subscription
    robls99 Well-Known Member Thread Starter
    Why do my customize desktop icons in XP sometimes convert back to the default icon.
    99% of them seem to hold the customized icon just fine.
    The one that often changes has the file actually stored on my wife's computer which I access over our home network.
    When I look at the Properties the customized icon is still there and the box checked Read Only is still checked.
    All I do is temp uncheck the Read Only and then click Apply and the correct icon pops back on the desktop.
    Why can't I lock it in permanently???
  2. 2013/08/09
    If you have more then 10 or 20 desktop shortcuts - move most of them to a folder on the desktop and see if that help.
    Steve,
    Thanks.
    I have about 50 desktop shortcuts and I LIKE them!
    Why does the quantity matter?
  5. 2013/08/09
    Each and everyone takes video power/memory to display them. The more graphic they are the more juice they need.
    Then again, I missed this part:
    If her computer is turned off, do the icons go dark?
    If so, move the file(s) to your computer:)
  6. 2013/08/10
    Duh!
    Thanks Steve, you hit the nail on the head.
    Actually turning her computer off leaves the icon intact.
    Even if I click on it, it goes nowhere but the icon still remains.
    It is only if I reboot when her computer is off, that the icon reverts to generic.
    Makes sense.
    Rob
