Where is START button info stored??
Discussion in 'Windows XP' started by RoadRUNNER, 2003/01/10.
  1. 2003/01/10
    RoadRUNNER
    RoadRUNNER Inactive Thread Starter
    I recently downloaded a program that REPLACES my task bar. I can create shortcuts. If I want to show a shortcut to my START button, where is it stored?
    Thank You
    RR :eek: :eek:
  2. 2003/01/11
    Abraxas
    Abraxas Inactive
    The Start Menu is an explorer function. Even the bitmap for the button is contained in explorer.exe and changing it involves hacking explorer.
    Unless someone has a better idea, I think the best you can do is make a shortcut to the Start Menu folder, either under each account name in Documents and Settings, or with:
    C:\WINDOWS\system32\config\systemprofile\Start Menu
    (if C: is your installation drive and "Windows" is your system folder).
    Making a shortcut that opens the menu without involving explorer is unlikely. You may just want to use the Windows key.
