When starting Firefox, stops & asks for Chome plug in
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by JohnChrysostom, 2009/03/10.
  1. 2009/03/10
    JohnChrysostom
    JohnChrysostom Inactive Thread Starter
    Recently Firefox stops its opening sequence as it says it needs a "Chrome" plug in?
    Whatsup? I do not have Chrome installed. I have no idea why Firefox wants a Chrome plug in installed.
    How do I eliminate this annoying request?
  2. 2009/03/10
    Welcome to WindowsBBS;)
    Does it give you the option to install the plug in?
    JohnChrysostom
    NO, that's part of anoyance. If it did, I'd say no if I could.
  5. 2009/03/10
    This is better served in the Firefox forum - moved. OP is running Vista.
  6. 2009/03/10
    Westside
    Westside Inactive Alumni
    I had never heard of a Chrome plugin until I did a search, and, pretty much as expected there is an add-on which allows one to view in Firefox with Google Chrome engine, very much like there is an IE Tab add-on to view with the IE engine. I would expect that Google Chrome should be installed for this thing to work. Beats me why the nag would continue, but possibly there was a check mark if Google Chrome was installed, or a certain website visited. Firefox has two Chrome folders, one in the program, and another one in the profile, but this is an entirely different beast.
