Resolved When does XP create a Restore Point?
Discussion in 'Windows XP' started by jpChris, 2010/12/17.
  1. 2010/12/17
    jpChris
    jpChris Inactive Thread Starter
    Hi all,
    I'm having a problem with System Restore Points in that only one point is saved "” and, no, I haven't changed any settings.
    So, I was wondering when XP decides to create a RP (other than when installing\deleting programs and a Restore Point is created)?
    I've searched the Google and I've read that it's anywhere from 24 hours of idle time to when you shut down.
  2. 2010/12/17
    Hi Chris. You read correctly. By default Windows XP creates a restore point once every 24 hours when your computer is idle. If only one restore point in being created and saved at a time its possible that the amount of disk space used by system restore is set to low. Try this, click Start< Right click My Computer and click properties. Click the System Restore tab.
    Make sure your harddrive is selected and then click the settings button. Make sure the disk space usage slider is set to the maximum amount which is 12%. When done click ok to close the window and click ok again to close the system properties window.
    susanai likes this.
    goddez1
    goddez1 Inactive
    Never mind. Evan has you covered, which is a good thing cause I didn't read this post correctly anyway. So sorry.
    howdy jpChris,
    For the archives and shared in an effort not to have posted an empty handed thread here.
    http://www.microsoft.com/windowsxp/u...w_03may19.mspx
  5. 2010/12/17
    goddez1
    goddez1 Inactive
    to add to my shame and embarrasment I have double posted. Crappppp!
  6. 2010/12/17
    Its ok Ann. We all make mistakes once in a while. ;)
  7. 2010/12/18
    How much free space do you have available on your System drive?
  8. 2010/12/18
    jpChris
    @ Goddez1,
    S' OK. I asked about how to delete a post that I'd made a mistake in and found out I couldn't. Oh, well.
    @ Evan,
    I've got my size set to 4% (232MB) and it's been that way for years. I've always had at least 4 restore points because my RPs are anywhere from 39MB to 42MB historically.
    As far as the 24 hour thingy, I've never had my computer on for 24 hours. I use it, click my screen saver when I'm going to be away, and it's autoset to go into Standby mode after one hour. Again, it's been this way with no problems for years.
    @ Arie,
    Used = 3.0 GB; Free = 4.5GB. I've read that Windows needs at least 200MB free, but I've got that covered by 4.3GB.
    Here's what I'm thinking: When I got the Desktop Security bug, I ran a lot of cleaning programs and one (or more) made changes to my system that I didn't want: Namely "” no Autorun (amongst others).
    I'm also thinking that SR in the registry got munged somehow; maybe by the bug?
    Do think a SysRestore repair is in order? I've got the "rstrui.exe" file in System32\DLLCache folder and in System32\Restore folder. I also have a Kelly's-Korner link.
  9. 2010/12/18
    Try turning off System Restore, rebooting the PC and then turning it on again. This will delete all the system restore points and you will be able to start System Restore from scratch.
    If that doesn't work try increasing the amount of harddrive space used by system restore to greater than just 4%.
  10. 2010/12/18
    jpChris
    Hi Evan,
    I've already turned SysRest off an on several times — no joy.
    And as far as increasing the size, I've had it at 4% for about 6 or 7 years now. Why\What would make it go wonky?
  11. 2010/12/18
    I wouldn't know unless there is a program that is interfering with System Restore.
    Did you make any recent changes to the computer before the problem occurred?
  12. 2010/12/19
    Nope. 10% is the absolute minimum, and I wouldn't want to go below 15% myself.
    You have only 3.75% free, that's asking for trouble.
  13. 2010/12/19
    jpChris
    Nope. The only "changes" I made were running programs to clean the Desktop Security bug a couple of months ago.
    I checked Kelly's-Korner for SysRest and the .reg files on her site match what's already there in my Registry.
    I increased my RP size to 344MB; we'll see if that makes a difference.
    @Arie,
    I've got a 120GB drive in 3 partitions — with C: set to 7.5GB — for a reason: If I catch a "bug ", it'll be on the C drive. Also, all scans, defrags, etc., go much quicker looking through 3GB rather than 65GB (total of C:, D:, and E).
    Plus, I don't need GB's of Restore Points. I always try out everything on my "Breakme" drive first; if "it" works and\or I like it, I'll do it on my main drive.
    I really don't need more than 4 or 5 Restore Points: consecutively. And that's what I'm trying to dope out — how to get consecutive RP's.
    Anyone know of a .VBS script that will auto create a RP on startup?
  14. 2010/12/19
    markmadras
    markmadras Banned
  15. 2010/12/19
    jpChris
    Hi Mark,
    Thanks for the link. I increased my RP allotment and created the .VBS file and put it in my Startup Folder.
    I'll check it for a few days to make sure it's behaving.
    Thanks, again, Mark.
  16. 2010/12/19
    markmadras
    markmadras Banned
    Your welcome:)
  17. 2010/12/27
    jpChris
    After monitoring my RPs for several days it was still wonky. When I used the "createrp" app it would create a RP, but, MS would add one also.
    So, some days I'd have one RP and some days I'd have 2.
    I finally got tired of fooling around with it and did what I should have done in the first place: Turn off SysRestore, reboot, re-enable, then do a repair\install of SR.SYS.
    Now my RPs are being saved "” although not daily. I've got the 22nd through the 25th, but not the 26th nor today (27th)(so far, anyway).
    I'll continue to monitor "it" for the next few days and if it appears to be behaving, I'll mark this as "Resolved ".
    Otherwise I'll be back with more misbehavior info.
  18. 2011/01/05
    jpChris
    Update
    Well, System Restore seems to be working correctly after reinstalling it. My RP's are being saved according to the amount of time I have the computer on. A RP will be saved on Monday, but if I only have the computer on for a few hours, another RP won't be created until Wednesday "” which is OK.
    However, when I do a Windows Cleanup and I tick the box for "Delete all but the most recent RP" it deletes all but the day before.
    Should I star another thread asking if there's a registry tweak that will delete all but the last two RPs?
  19. 2011/01/05
    mhein
    mhein Well-Known Member
    Hey All,
    Many thanks for this discussion.... I've been ignoring this feature for a while now.
    With all the apps and system changes most folks go through on a regular basis, I'm setting up a weekly schedule to keep this feature "clean ".
  20. 2011/01/05
    markmadras
    markmadras Banned
    JpChris, sounds like it is all working how it should.
    Not sure if this is possible but if you only want to keep the last two RP's you may be able to reduce the allocated drive space so that it only has room to save two RP's
  21. 2011/01/05
    jpChris
    Hi Mark,
    Now that it's behaving, I'll cut back on the percentage to about 5% or so. I really don't need a dozen or more RPs.
    I'd just like to know if I can save 2 RPs during a clean-up? — New post?
