What To Do With XP Machine After April Of 2014
Discussion in 'Windows XP' started by James Martin, 2013/08/26.
  1. 2013/08/26
    James Martin
    James Martin Geek Member Thread Starter
    Is there any way to securely network an old XP computer (to Windows 7, 8) after its EOL (end of life)?
    I hate to just let the thing sit unused. I have a lot of old files on it.
    Would it make sense to turn the old machine into a home server of sorts?
  2. 2013/08/27
    lj50 Lifetime Subscription
    lj50,
    James Martin
    Thanks, lj50, but my hardware is not up to snuff for anything newer than XP.
    I guess I could take the harddrive (EIDE) out of the old machine and use it for storage, but I would need an SATA adapter so it would run on the new board. Not sure what to do right now. Is there a way to securely connect XP to Windows 7 without an Ethernet cable?
  6. 2013/08/27
    James Martin
  7. 2013/08/27
    Could always put it in an external case and plug in via USB, but if the drive is really old false economy to put any trust in it IMO.
  8. 2013/08/27
    James Martin
    It's a five year old Western Digital Caviar.
    Is there another way to link my XP machine to my Windows 7 unit without a broadband cable? If so, that would make XP unable to access the web?
  9. 2013/08/27
    Depending on the hardware, you can use it as a file server. If you upgrade the hard disk, it may serve you well for some more time.
    Check out FreeNAS or Zentyal. You can also load an all purpose Linux distro like Ubuntu.
    James Martin likes this.
  10. 2013/08/27
    James Martin
    Interesting.
    Thanks for posting.
