what is the best color setting?
Discussion in 'Legacy Windows' started by crystalwoman, 2003/01/09.
  1. 2003/01/09
    crystalwoman
    crystalwoman Inactive Thread Starter
    I do not know which is better to use.
    I have 16 or 32 bit color settings, no less High or True.
    I am on 800 x 600 16 bit High now.
    Just wondering...thanks. :)
  2. 2003/01/10
    Topdog
    Topdog Inactive
    32 bit colour will make some pictures and images take a little longer to load due to more bits and maybe consume a little more memory, but depending on your system you may not even notice..try it and see, then you can make up your own mind. It's mostly a personal thing as far as results go
    and some things do look better with 32 bit.
    crystalwoman
    RE: best color setting?
    I did not see much difference really!? I had asked as i was not sure if there ought to be either. My friend has his set at 16 bit True and i noted his color looked sharper on his screen, so i was just wondering. Thanks again.
  5. 2003/01/16
    LLDJ
    LLDJ Inactive
    Recommendation
    My advice for you, my friend is to use a 800*600 display if you have a 14 "-15" monitor. if else, definitely consider using at least 1024*768*16bit, and even higher, depending on your monitor (some can get up to 1600*1200*32bit)
    rememer this:
    the bigger the display size, the more romm you'll have...
    good luck!!
    LLDJ,
    Beauty is in the eyes of the beer holder. In other words, try the different setting till you find one YOU like best.
