What is system32\kdkpt.exe? Is it safe?
Discussion in 'Malware and Virus Removal Archive' started by Russ Vaughan, 2008/07/11.
  1. 2008/07/11
    Russ Vaughan
    Russ Vaughan Inactive Thread Starter
    WinPatrol detected a new program not previously installed on my computer attempting to add itself to computer startup: C:\WINDOWS\system32\kdkpt.exe
    WinPatrol notes that no description, company name, nor copyright information is included. The WinPatrol alert is repeatedly appearing.
    Should I allow kdkpt.exe to be added to startup? If not, how do I get rid of it?
    Thank you, Russ
  2. 2008/07/11
    Forsaken Knight
    Forsaken Knight Well-Known Member
    Response, check up on info required.
    I would like to help you find out what that file exactly is, so that the other users of this site may better assist you. However, looking up that file name, and various alternative forms of it, (just in case you misspelled it), showed no results.
    Could you manually look up the file it self in your computer? As well as run a scan, whether thorough, or specifically, to find that file. Please state what you use to implement the scan, and a summary of your findings, (details are usually asked upon request around here).
    All the best, see you when you get back to check on this.
    Oh, and you should know, that the look up of just "kdkpt" comes up with 61 total findings on google.com, 82 on msn, and 25 on yahoo. That is what I found, I'll look through some of them, but I advise you to do the same thing with your search as well.
    Russ - Welcome to the Board :)
    Anything which does not show up in Google is bad news - is this the correct spelling - kdkpt.exe ?
    Read this and post the logs requested in your next post in this thread - spread over 2 posts if necessary .
  5. 2008/07/12
    Russ Vaughan
    RE: What is system32\kdkpt.exe? Is it safe?
    Thank you gentlemen.
    kdkpt is correct; see the attached Decker scan. However, I was not able to find the program using My Computer to review the contents of system32.
    Deckard's System Scanner v20071014.68
    Run by Grand Pooba on 2008-07-10 13:58:10
    Computer is in Normal Mode.
    -- System Restore --------------------------------------------------------------
    Successfully created a Deckard's System Scanner Restore Point.
    -- Last 5 Restore Point(s) --
    88: 2008-07-10 17:58:21 UTC - RP110 - Deckard's System Scanner Restore Point
    87: 2008-07-10 17:22:22 UTC - RP109 - Spybot-S&D Spyware removal
    86: 2008-07-10 14:29:37 UTC - RP108 - System Checkpoint
    85: 2008-07-09 13:40:31 UTC - RP107 - System Checkpoint
    84: 2008-07-08 11:52:05 UTC - RP106 - System Checkpoint
    -- First Restore Point --
    1: 2008-04-11 18:36:35 UTC - RP23 - Spybot-S&D Spyware removal
    Backed up registry hives.
    Performed disk cleanup.
    -- HijackThis Clone ------------------------------------------------------------
    Emulating logfile of Trend Micro HijackThis v2.0.2
    Scan saved at 2008-07-10 14:01:27
    Platform: Windows XP Service Pack 2 (5.01.2600)
    MSIE: Internet Explorer (6.00.2900.2180)
    C:\WINDOWS\system32\smss.exe
    C:\WINDOWS\system32\csrss.exe
    C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
    C:\Program Files\Lavasoft\Ad-Aware 2007\aawservice.exe
    C:\Program Files\a-squared Free\a2service.exe
    C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
    C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
    C:\Program Files\Symantec\Norton Ghost 2003\GhostStartService.exe
    C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
    C:\WINDOWS\system32\nvsvc32.exe
    C:\Program Files\Analog Devices\SoundMAX\SMAgent.exe
    C:\Program Files\Intel\Intel(R) Active Monitor\imonNT.exe
    C:\WINDOWS\system32\alg.exe
    C:\WINDOWS\system32\WgaTray.exe
    C:\WINDOWS\explorer.exe
    C:\Program Files\Intel\Intel(R) Active Monitor\imontray.exe
    C:\Program Files\Analog Devices\SoundMAX\SMTray.exe
    C:\WINDOWS\system32\TaskSwitch.exe
    C:\Program Files\Symantec\Norton Ghost 2003\GhostStartTrayApp.exe
    C:\Program Files\BillP Studios\WinPatrol\WinPatrol.exe
    C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe
    C:\Program Files\QuickTime\qttask.exe
    C:\Program Files\ScanSoft\OmniPageSE2.0\opwareSE2.exe
    C:\Program Files\Babylon\Babylon-Pro\Babylon.exe
    C:\Program Files\Creative\Sync Manager Unicode\CTSyncU.exe
    C:\Program Files\Google\Google Updater\GoogleUpdater.exe
    C:\Program Files\WiFiConnector\NintendoWFCReg.exe
    C:\Program Files\Common Files\Symantec Shared\VAScanner\comHost.exe
    C:\Program Files\Microsoft Office\OFFICE11\WINWORD.EXE
    C:\Program Files\Adobe\Acrobat 5.0\Reader\AcroRd32.exe
    C:\Program Files\Netscape\Netscape\Netscp.exe
    C:\Documents and Settings\Grand Pooba\Desktop\dss.exe
    C:\Program Files\Common Files\Symantec Shared\COH\COH32.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://www.google.com/ie
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.google.com/ie
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://www.google.com
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.drudgereport.com/
    R1 - HKCU\Software\Microsoft\Internet Explorer\Search,Default_Search_URL = http://www.google.com/ie
    R1 - HKCU\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://www.google.com/ie
    R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://www.google.com/search?q=%s
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = http=127.0.0.1:6711
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://www.google.com/ie
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://ms101.mysearch.com/sa/srchlft.html
    R1 - HKLM\Software\Microsoft\Internet Explorer\Search,Default_Search_URL = http://www.google.com/ie
    R1 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://www.google.com/ie
    R3 - URLSearchHook: myBabylon Toolbar - {34ea1c70-42cc-42c5-aa29-ec58b95a343e} - C:\Program Files\myBabylon\tbmyB0.dll
    O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O2 - BHO: NCO 2.0 IE BHO - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - C:\Program Files\Common Files\Symantec Shared\coShared\Browser\2.6\CoIEPlg.dll
    O2 - BHO: Symantec Intrusion Prevention - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files\Common Files\Symantec Shared\IDS\IPSBHO.dll
    O2 - BHO: My Web Search Bar BHO - {8EAB99C1-F9EC-4b64-A4BA-D9BCAE8779C2} - C:\Program Files\MyWebSearchWB\bar\1.bin\W6BAR.DLL (file missing)
    O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\3.0.1225.9868\swg.dll
    O3 - Toolbar: WeatherBug Browser Bar - powered by MyWebSearch - {8EAB99C9-F9EC-4b64-A4BA-D9BCAE8779C2} - C:\Program Files\MyWebSearchWB\bar\1.bin\W6BAR.DLL (file missing)
    O3 - Toolbar: Easy-WebPrint - {327C2873-E90D-4c37-AA9D-10AC9BABA46C} - C:\Program Files\Canon\Easy-WebPrint\Toolband.dll
    O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\GoogleToolbar3.dll
    O3 - Toolbar: Show Norton Toolbar - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files\Common Files\Symantec Shared\coShared\Browser\2.6\CoIEPlg.dll
    O3 - Toolbar: myBabylon Toolbar - {34ea1c70-42cc-42c5-aa29-ec58b95a343e} - C:\Program Files\myBabylon\tbmyB0.dll
    O4 - HKLM\..\Run: [IMONTRAY] C:\Program Files\Intel\Intel(R) Active Monitor\imontray.exe
    O4 - HKLM\..\Run: [Smapp] C:\Program Files\Analog Devices\SoundMAX\Smtray.exe
    O4 - HKLM\..\Run: [CoolSwitch] C:\WINDOWS\System32\taskswitch.exe
    O4 - HKLM\..\Run: [GhostStartTrayApp] C:\Program Files\Symantec\Norton Ghost 2003\GhostStartTrayApp.exe
    O4 - HKLM\..\Run: [WinPatrol] "C:\PROGRA~1\BILLPS~1\WINPAT~1\WinPatrol.exe "
    O4 - HKLM\..\Run: [osCheck] "C:\Program Files\Norton 360\osCheck.exe "
    O4 - HKLM\..\Run: [!AVG Anti-Spyware] "C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe" /minimized
    O4 - HKLM\..\Run: [UserFaultCheck] %systemroot%\system32\dumprep 0 -u
    O4 - HKLM\..\Run: [OpwareSE2] "C:\Program Files\ScanSoft\OmniPageSE2.0\OpwareSE2.exe "
    O4 - HKLM\..\Run: [Babylon Client] C:\Program Files\Babylon\Babylon-Pro\Babylon.exe -AutoStart
    O4 - HKLM\..\Run: [C:\WINDOWS\system32\kdkpt.exe] C:\WINDOWS\system32\kdkpt.exe
    O4 - HKCU\..\Run: [Mozilla Quick Launch] "C:\Program Files\Netscape\Netscape\Netscp.exe" -turbo
    O4 - HKCU\..\Run: [CTSyncU.exe] "C:\Program Files\Creative\Sync Manager Unicode\CTSyncU.exe "
    O4 - HKUS\S-1-5-18\..\Run: [Picasa Media Detector] C:\Program Files\Picasa2\PicasaMediaDetector.exe (User 'SYSTEM')
    O4 - HKUS\.DEFAULT\..\Run: [Picasa Media Detector] C:\Program Files\Picasa2\PicasaMediaDetector.exe (User 'Default user')
    O4 - Global Startup: Google Updater.lnk = C:\Program Files\Google\Google Updater\GoogleUpdater.exe
    O4 - Global Startup: Run Nintendo Wi-Fi USB Connector Registration Tool.lnk = C:\Program Files\WiFiConnector\NintendoWFCReg.exe
    O8 - Extra context menu item: &eBay Search - res://C:\Program Files\eBay\eBay Toolbar2\eBayTb.dll/RCSearch.html
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
    O8 - Extra context menu item: Easy-WebPrint Add To Print List - res://C:\Program Files\Canon\Easy-WebPrint\Resource.dll/RC_AddToList.html
    O8 - Extra context menu item: Easy-WebPrint High Speed Print - res://C:\Program Files\Canon\Easy-WebPrint\Resource.dll/RC_HSPrint.html
    O8 - Extra context menu item: Easy-WebPrint Preview - res://C:\Program Files\Canon\Easy-WebPrint\Resource.dll/RC_Preview.html
    O8 - Extra context menu item: Easy-WebPrint Print - res://C:\Program Files\Canon\Easy-WebPrint\Resource.dll/RC_Print.html
    O8 - Extra context menu item: Translate with &Babylon - res://C:\Program Files\Babylon\Babylon-Pro\Utils\BabylonIEPI.dll/Translate.htm
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - (no file)
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - (no file)
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - (file missing)
    O16 - DPF: {0A5FD7C5-A45C-49FC-ADB5-9952547D5715} (Creative Software AutoUpdate) - http://www.creative.com/su/ocx/15031/CTSUEng.cab
    O16 - DPF: {2B96D5CC-C5B5-49A5-A69D-CC0A30F9028C} () - http://wdownload.weatherbug.com/minibug/tricklers/AWS/MiniBugTransporter.cab?
    O16 - DPF: {33564D57-0000-0010-8000-00AA00389B71} () - http://download.microsoft.com/download/F/6/E/F6E491A6-77E1-4E20-9F5F-94901338C922/wmv9VCM.CAB
    O16 - DPF: {3AF4DACE-36ED-42EF-9DFC-ADC34DA30CFF} (PatchInstaller.Installer) - file://D:\content\include\XPPatchInstaller.CAB
    O16 - DPF: {9F1C11AA-197B-4942-BA54-47A8489BB47F} () - http://v4.windowsupdate.microsoft.com/CAB/x86/unicode/iuctl.CAB?38143.7529050926
    O16 - DPF: {A93D84FD-641F-43AE-B963-E6FA84BE7FE7} () - http://www.linksysfix.com/netcheck/51/install/gtdownls.cab
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - https://fpdownload.macromedia.com/get/flashplayer/current/swflash.cab
    O16 - DPF: {F6ACF75C-C32C-447B-9BEF-46B766368D29} (Creative Software AutoUpdate Support Package) - http://www.creative.com/su/ocx/15034/CTPID.cab
    O17 - HKLM\SYSTEM\CCS\Services\Tcpip\..\{5790FAB5-848A-46E1-B6A6-E686D8C0AC7B}: NameServer = 85.255.114.89,85.255.112.196
    O17 - HKLM\SYSTEM\CCS\Services\Tcpip\..\{8C566F24-6881-4812-A27F-AA225B4966D7}: NameServer = 85.255.114.89,85.255.112.196
    O17 - HKLM\SYSTEM\CCS\Services\Tcpip\..\{F469B2BC-4802-406F-ACC8-6241CE94598F}: NameServer = 85.255.114.89,85.255.112.196
    O17 - HKLM\SYSTEM\CS1\Services\Tcpip\Parameters: NameServer = 208.67.220.220,208.67.222.222
    O17 - HKLM\SYSTEM\CS2\Services\Tcpip\Parameters: NameServer = 85.255.114.89 85.255.112.196
    O17 - HKLM\SYSTEM\CCS\Services\Tcpip\Parameters: NameServer = 208.67.220.220,208.67.222.222
    O18 - Protocol: belarc - {6318E0AB-2E93-11D1-B8ED-00608CC9A71F} - C:\Program Files\Belarc\Advisor\System\BAVoilaX.dll
    O18 - Protocol: lid - {5C135180-9973-46D9-ABF4-148267CBB8BF} - C:\WINDOWS\system32\msvidctl.dll
    O18 - Protocol: ms-itss - {0A9007C0-4076-11D3-8789-0000F8105754} - C:\Program Files\Common Files\Microsoft Shared\Information Retrieval\msitss.dll
    O18 - Protocol: mso-offdap - {3D9F03FA-7A94-11D3-BE81-0050048385D1} - C:\Program Files\Common Files\Microsoft Shared\Web Components\10\OWC10.DLL
    O18 - Filter: text/xml - {807553E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\Microsoft Shared\OFFICE11\MSOXMLMF.DLL
    O20 - AppInit_DLLs: gdi16.dll
    O23 - Service: a-squared Free Service (a2free) - Emsi Software GmbH - C:\Program Files\a-squared Free\a2service.exe
    O23 - Service: Ad-Aware 2007 Service (aawservice) - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware 2007\aawservice.exe
    O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
    O23 - Service: AVG Anti-Spyware Guard - GRISOFT s.r.o. - C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
    O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: Symantec Lic NetConnect service (CLTNetCnService) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: COM Host (comHost) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\VAScanner\comHost.exe
    O23 - Service: GhostStartService - Symantec Corporation - C:\Program Files\Symantec\Norton Ghost 2003\GhostStartService.exe
    O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
    O23 - Service: Intel(R) Active Monitor (imonNT) - Intel Corp. - C:\Program Files\Intel\Intel(R) Active Monitor\imonNT.exe
    O23 - Service: LiveUpdate - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\LuComServer_3_4.EXE
    O23 - Service: LiveUpdate Notice - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
    O23 - Service: SoundMAX Agent Service (SoundMAX Agent Service (default)) - Analog Devices, Inc. - C:\Program Files\Analog Devices\SoundMAX\SMAgent.exe
    O23 - Service: Symantec Core LC - Unknown owner - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
    O23 - Service: Symantec RemoteAssist - Symantec, Inc. - C:\Program Files\Common Files\Symantec Shared\Support Controls\ssrc.exe
    O23 - Service: Security Center (wscsvc) - Unknown owner - C:\WINDOWS\C:\WINDOWS\System32\svchost.exe -k netsvcs
    O24 - Desktop Component 0: Privacy Protection - file:///C:\WINDOWS\privacy_danger\index.htm
    End of file - 13219 bytes
    -- File Associations -----------------------------------------------------------
    All associations okay.
    -- Drivers: 0-Boot, 1-System, 2-Auto, 3-Demand, 4-Disabled ---------------------
    R0 Imagedrv - c:\windows\system32\drivers\imagedrv.sys <Not Verified; Ahead Software AG and its licensors; NERO IMAGEDRIVE>
    R1 BANTExt (Belarc SMBios Access) - c:\windows\system32\drivers\bantext.sys
    R1 GhPciScan (GhostPciScanner) - c:\program files\symantec\norton ghost 2003\ghpciscan.sys <Not Verified; Symantec Corporation; Symantec Ghost PCI Scanner>
    R2 ASCTRM - c:\windows\system32\drivers\asctrm.sys <Not Verified; Windows (R) 2000 DDK provider; Windows (R) 2000 DDK driver>
    R2 SIODRV - c:\windows\system32\drivers\siodrv.sys <Not Verified; Intel Corporation; Intel(R) Active Monitor>
    R3 SMBios (Intel (R) System Management BIOS Service) - c:\windows\system32\drivers\smbios.sys <Not Verified; Intel Corporation; Intel (R) System Management BIOS Driver>
    R3 smbusp (Intel(R) SMBus 2.0 Driver) - c:\windows\system32\drivers\smb.sys <Not Verified; Intel Corporation; Intel(R) SMBus Controller>
    S2 LXARScan (Lexmark X73 MFP Scanner) - c:\windows\system32\drivers\lxarscan.sys (file missing)
    S3 RT25USBAP (Nintendo Wi-Fi USB Connector Service) - c:\windows\system32\drivers\rt25usbap.sys <Not Verified; Ralink Technology Inc.; Ralink 802.11g Wireless USB Adapters>
    -- Services: 0-Boot, 1-System, 2-Auto, 3-Demand, 4-Disabled --------------------
    R2 GhostStartService - c:\progra~1\symantec\norton~1\ghosts~2.exe <Not Verified; Symantec Corporation; Norton Ghost Start Service>
    R2 imonNT (Intel(R) Active Monitor) - c:\program files\intel\intel(r) active monitor\imonnt.exe <Not Verified; Intel Corp.; Intel(R) Active Monitor>
    S2 wscsvc (Security Center) - \systemroot\c:\windows\system32\svchost.exe -k netsvcs (file missing)
    -- Device Manager: Disabled ----------------------------------------------------
    Class GUID: {4D36E972-E325-11CE-BFC1-08002BE10318}
    Description: Intel(R) PRO/100 VE Network Connection
    Device ID: PCI\VEN_8086&DEV_2449&SUBSYS_30138086&REV_03\4&1351887D&0&40F0
    Manufacturer: Intel
    Name: Intel(R) PRO/100 VE Network Connection
    PNP Device ID: PCI\VEN_8086&DEV_2449&SUBSYS_30138086&REV_03\4&1351887D&0&40F0
    Service: E100B
    -- Files created between 2008-06-10 and 2008-07-10 -----------------------------
    2100-02-23 15:35:34 768 --a------ C:\Program Files\x73_lut.dat
    2100-02-08 16:03:54 53248 --a------ C:\Program Files\ACMonitor_X73.exe <Not Verified; Silitek Corp.; ACMonitor>
    2008-07-10 01:39:35 0 dr-h----- C:\Documents and Settings\Grand Pooba\Recent
    2008-07-01 21:57:57 0 d--hs---- C:\found.001
    2008-06-27 03:17:23 17920 --a------ C:\WINDOWS\system32\ks94.dll
    2008-06-27 03:17:04 17920 --a------ C:\WINDOWS\system32\ascisys.dll
    2008-06-19 17:44:26 0 d-------- C:\Documents and Settings\Grand Pooba\Application Data\Opera
    2008-06-19 17:07:02 0 d-------- C:\Program Files\Opera
    -- Find3M Report ---------------------------------------------------------------
    2008-07-10 14:01:17 0 d-------- C:\Program Files\Common Files\Symantec Shared
    2008-07-05 13:49:59 0 d-------- C:\Program Files\myBabylon
    2008-07-01 21:59:04 0 d-------- C:\Program Files\Norton 360
    2008-06-27 13:42:39 0 d-------- C:\Program Files\a-squared Free
    2008-06-14 02:43:33 0 d-------- C:\Program Files\Symantec
    2008-06-01 13:23:03 0 d-------- C:\Documents and Settings\Grand Pooba\Application Data\WinRAR
    2008-05-26 11:19:28 0 d-------- C:\Documents and Settings\Grand Pooba\Application Data\Creative
    2008-04-22 15:23:49 737280 --a------ C:\WINDOWS\iun6002.exe <Not Verified; Indigo Rose Corporation; Setup Factory 6.0 Runtime Module>
    -- Registry Dump ---------------------------------------------------------------
    [HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{602ADB0E-4AFF-4217-8AA1-95DAC4DFA408}]
    06/30/2008 01:44 PM 349552 --a------ C:\Program Files\Common Files\Symantec Shared\coShared\Browser\2.6\coIEPlg.dll
    [HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{6D53EC84-6AAE-4787-AEEE-F4628F01010C}]
    03/20/2008 05:59 PM 116088 --a------ C:\PROGRA~1\COMMON~1\SYMANT~1\IDS\IPSBHO.dll
    [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser]
    "{7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} "= C:\Program Files\Common Files\Symantec Shared\coShared\Browser\2.6\CoIEPlg.dll [06/30/2008 01:44 PM 349552]
    "{34EA1C70-42CC-42C5-AA29-EC58B95A343E} "= C:\Program Files\myBabylon\tbmyB0.dll [07/05/2008 01:50 PM 1569304]
    [-HKEY_CLASSES_ROOT\CLSID\{7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA}]
    [HKEY_CLASSES_ROOT\CoIEPlg.CoToolbar.1]
    [HKEY_CLASSES_ROOT\CoIEPlg.CoToolbar]
    [-HKEY_CLASSES_ROOT\CLSID\{34EA1C70-42CC-42C5-AA29-EC58B95A343E}]
    "IMONTRAY "= "C:\Program Files\Intel\Intel(R) Active Monitor\imontray.exe" [03/10/2004 10:02 PM]
    "Smapp "= "C:\Program Files\Analog Devices\SoundMAX\Smtray.exe" [06/26/2002 05:36 PM]
    "CoolSwitch "= "C:\WINDOWS\System32\taskswitch.exe" [03/19/2002 05:30 PM]
    "GhostStartTrayApp "= "C:\Program Files\Symantec\Norton Ghost 2003\GhostStartTrayApp.exe" [08/14/2002 03:21 PM]
    "WinPatrol "= "C:\PROGRA~1\BILLPS~1\WINPAT~1\WinPatrol.exe" [05/06/2004 02:17 PM]
    "ccApp "= "C:\Program Files\Common Files\Symantec Shared\ccApp.exe" [02/18/2008 03:37 PM]
    "osCheck "= "C:\Program Files\Norton 360\osCheck.exe" [02/26/2008 10:50 AM]
    "!AVG Anti-Spyware "= "C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe" [06/11/2007 05:25 AM]
    "UserFaultCheck "= "C:\WINDOWS\system32\dumprep 0 -u" []
    "QuickTime Task "= "C:\Program Files\QuickTime\qttask.exe" [06/05/2004 10:46 PM]
    "OpwareSE2 "= "C:\Program Files\ScanSoft\OmniPageSE2.0\OpwareSE2.exe" [05/08/2003 12:00 PM]
    "Babylon Client "= "C:\Program Files\Babylon\Babylon-Pro\Babylon.exe" [03/11/2008 09:23 AM]
    "C:\WINDOWS\system32\kdkpt.exe "= "C:\WINDOWS\system32\kdkpt.exe" [06/13/2007 06:23 AM]
    "Mozilla Quick Launch "= "C:\Program Files\Netscape\Netscape\Netscp.exe" [06/24/2003 12:09 PM]
    "CTSyncU.exe "= "C:\Program Files\Creative\Sync Manager Unicode\CTSyncU.exe" [09/28/2006 09:09 PM]
    [HKEY_USERS\.default\software\microsoft\windows\currentversion\run]
    "Picasa Media Detector "=C:\Program Files\Picasa2\PicasaMediaDetector.exe
    C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
    Google Updater.lnk - C:\Program Files\Google\Google Updater\GoogleUpdater.exe [4/20/2008 4:40:21 PM]
    Run Nintendo Wi-Fi USB Connector Registration Tool.lnk - C:\Program Files\WiFiConnector\NintendoWFCReg.exe [8/21/2007 10:42:35 AM]
    [HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\system]
    "DisableRegistryTools "=0 (0x0)
    [HKEY_CURRENT_USER\software\microsoft\internet explorer\desktop\components\0]
    Source= file:///C:\WINDOWS\privacy_danger\index.htm
    FriendlyName= Privacy Protection
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon]
    "system "= "kdkpt.exe "
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\windows]
    "appinit_dlls "=gdi16.dll
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\aawservice]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\vds]
    @= "Service "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{533C5B84-EC70-11D2-9505-00C04F79DEAF}]
    @= "Volume shadow copy "
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run-]
    "QuickTime Task "= "C:\Program Files\QuickTime\qttask.exe" -atboottime
    "RemoteControl "= "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe "
    "NeroFilterCheck "=C:\WINDOWS\system32\NeroCheck.exe
    "Microsoft Works Update Detection "=C:\Program Files\Common Files\Microsoft Shared\Works Shared\WkUFind.exe
    *Newly Created Service* - COMHOST
    -- End of Deckard's System Scanner: finished at 2008-07-10 14:06:04 ------------
  6. 2008/07/13
    noahdfear
    noahdfear Inactive
    Hi Russ :)
    Download ComboFix by sUBs from here, saving the file to your desktop.
    Please disable realtime protection applications as they sometimes interfere with the tool. Check this link for your applicable programs.
    • Close all open programs and windows
    • Double click combofix.exe and follow the prompts.
    • It may reboot your computer and resume running when you logon. Wait for it to complete. When finished, it will open a log for you. Post that log in your next reply.
    Note: Do not mouseclick combofix's window while its running. That may cause it to stall
    I would also like for you to download and install HijackThis, scan and save a logfile, then post it here as well.
