What is "Java Web Start"????
Discussion in 'Other PC Software' started by chrisw, 2004/06/16.
  1. 2004/06/16
    chrisw
    chrisw Inactive Thread Starter
    I have this software (Sun's ver 1.2) on my XP machine. Evidently some web sites (like the NY Times) use it to facilitate graphics [I think so, anyway, does anybody know? The JWS Help function is gobbledegook.]
    Anyway, whenever a site wants to use JWS, the site stops dead for a few seconds while the software loads....annoying. Is there anyway to have JWS startup at boot, so that it's always running in the background and thus immediately available? [I have very little background stuff running, adding JWS shouldn't slow things down appreciably.]
    BTW, If I click on "check for available updates ", I get "no updates available" even tho I suspect one may be available. If I go to the Sun Java site, it only talks about Java 2 Development Platform....no reference to anything called JavaWebStart that I can find. That's why I haven't been able to figure out what JWS even is. Thnx
  2. 2004/06/16
    Welshjim
    Welshjim Inactive
    chrisw
    jim...that seemed to lead me the right part of the Java web site, so thanks. It's still written in technogeek, not clear if I can download the new version on top of the old, or whether I should remove the old one first.
  5. 2004/06/16
    Welshjim
    Welshjim Inactive
    chrisw--Glad those references could be of some help. We New Mexicans have to stick together. :)
    Regarding uninstalling the older version of Java before installing the new, I did a quick search of their FAQ's
    http://java.sun.com/j2se/faq.html
    and found
    "Does the software update from Sun erase my previous version of Java?
    No. It installs a newer version of the Java Runtime Environment while leaving the existing versions intact. For example, a client machine can have the J2SE versions 1.3, 1.3.1, 1.3.1_02, and 1.4 installed at the same time without conflict. This is useful for when application provider A has only certified their application on version 1.3, while application provider B requires version 1.4 for additional features or functionality. There are no conflicts or collisions between JRE versions, as they all peacefully co-exist. "
    However, if you do not care about backward compatibility, it is rare that it hurts to uninstall an old version of a program before installing a newer one. I also saw at the bottom of one of Sun's pages
    http://java.sun.com/j2se/1.4.2/
    that they still offer old versions. So if you do uninstall the old version but want it back you can do so.
  6. 2004/06/17
    chrisw
    Jim.....thanks, maybe I'll summon up the courage and try the updated version (I'll purge the old one first, however)
    Chris (Santa Fe)
