weird java(?) problem
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by gator, 2003/11/23.
  1. 2003/11/23
    gator
    gator Inactive Thread Starter
    Ok I have a weird one that I can't figure out. I have installed Sun Java plug-in 1.4.2_02 with some luck. I have enabled Netsacpe 7.1, checked "use browser setting" and I can get part of a web page to load. The page that I am having troubles with is http://www.apeks.co.uk/apekshome.htm
    When I click on the product tab that drops down. I don't get the list of products in the side bar nor the background picture of a diver. I can get everything when I use IE. Searched the board for anything and nothing worked.
    I have unistalled and reinstalled so many times and different configurations that I don't remember them all. Any help would be greatly appreciated.
  2. 2003/11/23
    MinnesotaMike
    MinnesotaMike Geek Member
    gator,
    When I go to the site with Netscape 7, I get a Visual C++ error. If I choose Ignore, the page will load up okay. A little slow, but it loads. I also can get the drop down menu on the product tab. Although I prefer Netscape, I have just accepted that it won't open all pages. If you prefer not to use IE, you could try installing a Mozilla browser. I understand that they are very good. That is probably the direction I'm headed down the road.
    Sorry I couldn't give you a fix, but thought I'd pass on my experience with that page.
    Mike
