Resolved Web Page Help
Discussion in 'Internet Explorer & Microsoft Edge' started by erichcs, 2007/09/16.
  1. 2007/09/16
    erichcs
    erichcs Inactive Thread Starter
    When I go to www.komoradio.com and I am using windows vista home premium and internet explorer 7, I keep getting this message at the bottom of the screen a yellow triangle sign appears with a question mark saying done and problems with this web page might prevent it from displaying properly or functioning properly?
    How do adjust my settings so that I will not keep getting this message?
  2. 2007/09/17
    I see '! Done, but with errors on the page' in XP/IE7 - as the message says - click on the yellow shield > details - there is an error in the html that makes up the page.
    The only way of not seeing the message is to turn off the Status bar - View > uncheck Status bar. Drawback is that you will not then see the page loading bar, antiphishing filter, page magnification option, etc.
    What's the problem with seeing the message? It is informative.
