Web design software
Discussion in 'Web Applications & Cloud' started by babatunde, 2011/08/23.
  1. 2011/08/23
    babatunde
    babatunde Inactive Thread Starter
    What is the best software that i can used to design software.
  2. 2011/08/24
    Design software ?
    Do you want to create a web site or a software ?
    babatunde
    I can design website i just need a good software that can make it easy for me. Like CMS software. Right now am using dreamwaver to design but i cannot make forum etc
  5. 2011/08/24
    Dreamweaver is for designing Websites, though not very good at generating the code. It tends to add unnecessary tags and makes sloppy code.
    Web forums, blogs, CMS systems, etc, use software that is installed on the Web server itself. They require a database and a scripting engine such as PHP or Java.
    Many of these software packages have Web interfaces where you can change site themes and edit the pages directly via a browser. Wordpress is such an example.
    You can use any Web design software to generate the Web pages, but there's no shortcut to actually learning and using PHP, Java, etc.
    An expensive package that accommodates Dreamweaver is Cold Fusion.
    babatunde likes this.
  6. 2011/08/24
    babatunde
    interesting. That is the software i need. I have little experience in PHP codes.
