Wanting to learn how to install on both drives?
Discussion in 'Windows XP' started by nztwinkle, 2008/08/17.
  1. 2008/08/17
    nztwinkle
    nztwinkle Inactive Thread Starter
    Hello
    Could someone tell me in basic terms how to install windows xp pro on my E drive, I see some people have it on both of there drives, this would be handy for me, or is there a web site that can explain it in step by step.
  2. 2008/08/17
    surferdude2
    surferdude2 Inactive
    I find that XXCLONE makes that very easy. You don't have to go through the rigors of a second install since cloning will do all the work for you. No worry about activation either since the hardware doesn't change. The software also takes care of the drive letter issue when booting the clone. It automatically switches the drive letters of the system partition with the boot partition so that you are always booting a C: drive.
    I keep a cloned copy for my "Crash Dummy" projects and when it gets corrupt, I just clone over it again with my healthy system copy. It allows for operating fast and loose when testing new software and procedures that may be risky.
    PeteC likes this.
