Wallpaper problem
Discussion in 'Windows XP' started by Dragon007, 2004/06/29.
  1. 2004/06/29
    Dragon007
    Dragon007 Inactive Thread Starter
    I have had a problem--apparently I must of clicked on some ad and it was became my desktop wallpaper. I thought I eliminated the application that produced it, but it still comes up. I went into my desktop/wallpaper folder and deleted all the pictures that made up the wallpaper, but now I get a white screen that flickers off and on to an off-white color. I tried to change the wallpaper to the standard ones available and the only time I see it is when I boot up and when I turn off my computer. My desktop items are present, but I cannot group them together if I right click with my mouse. I did a search on the forums and tried what others have done including System restore (which my computer says it cannot restore to a previous point even on mulitple attempts to earlier days), downloading and running Startup CPL (which I don't find an abnormal application) and looking in to the Registry (the wallpaper listed is one available from Windows XP).
    My computer is running fine, but I just want to get rid of this annoying item!
    Thanks in advance for any advice!
  2. 2004/06/29
    scutter
    scutter Inactive
    Have you tried downloading ad-aware and spybot, then scanning your computer for pests?
    Dragon007
    Thanks for the rapid reply!
    Yes I have run both Adaware and Spybot without any result.
  5. 2004/06/30
    Might be worth running System File Checker - I don't know if it covers this area, but worth a try ....
    Start > Run > type in sfc /scannow - note the space and you will need your XP install CD. It will simply run and exit without any indication of any changes - to see what, if anything was changed look in Event Viewer.
