[Volume icon disappears when antivirus installed]
Discussion in 'Windows XP' started by Sparkle, 2006/05/21.
  1. 2006/05/21
    Sparkle
    Sparkle Inactive Thread Starter
    I can't find my sound icon on the desktop toolbar . Every time I install the antivirus it disappears. Itried with different antiviruses and happens the same.
    Who Can you give me a hand?
  2. 2006/05/22
    Sparkle - Welcome to the Board :)
    First check that in Control Panel > Sounds and Audio Devices that there is a check mark against 'Place volume icon on the Taskbar'. If it is not does checking it restore the icon?
    If not right click on the Taskbar > uncheck Lock the taskbar. Does the icon show - is there a small arrowhead at the left side of the Notification Area (by the clock). If so cicking on it will unhide/hide inactive icons. If the sound icon becomes visible righr click on the Taskbar > Propertes and uncheck 'Hde inactive icons > Apply. Then lock the Taskbar again.
    Post back with your findings.
    Sparkle
    Thanks Pete .but I've already tried all the things you've suggested me. The problem is with the antivirus. I tried 3 different ones and the only time I see the sound icon is when the antivirus is uninstalled.
    thanks anyway
    QUOTE=PeteC]Sparkle - Welcome to the Board :)
    Post back with your findings.[/QUOTE]
  5. 2006/05/23
    Very difficult to track down the cause of problems like this - I do not recall having seen anything like this before.
    There are a couple of other possible solutions here under Volume Control ....
    http://www.kellys-korner-xp.com/xp_v.htm
    I have edited your thread title in the hope that someone else will chip in on this.
