Volume Control Window no longer showing up
Discussion in 'Windows XP' started by mbay, 2005/08/29.
  1. 2005/08/29
    mbay
    mbay Inactive Thread Starter
    Hello Everyone!
    I am using windows xp. On the bottom right icon tray - where the sound control is - when i click on the volume control icon, the window panel no longer show up.
    What can i do?
    Thanks in advance!
    mbay,
  2. 2005/08/30
    mlegg10
    mlegg10 Inactive
    Windows cannot display the volume control on the taskbar because the Volume Control program has not been installed. To install it use Add/Remove Programs in Control Panel.
    To resolve this issue, extract a new copy of Sndvol32.exe from the Windows XP CD to the system_root \System32 folder on your computer's hard disk. To do this, follow these steps:
    Start/Run/CMD. In the command prompt window type:
    X: (where X is your CD Drive letter)
    CD \I386
    Then use the expand command: expand -r sndvol32.ex_ c:\windows\system32
    Note: This assumes XP is installed on C: and that its installed in the Windows folder. If not, you'll need to adjust the command accordingly. Additionally, this must be an installable version of XP, not a "recovery CD ".
    Read more here if you need to:
    http://www.kellys-korner-xp.com/xp_v.htm#volume
