Windows Vista Volume Control Icon on the Taskbar
Discussion in 'Legacy Windows' started by rocketpilot, 2007/07/10.
  1. 2007/07/10
    rocketpilot
    rocketpilot Inactive Thread Starter
    I'm new to this site, and new to Vista Ultimate. My Volume Control Icon has disappeared and there is no way that I can restore it. When I click on the Start icon, go to Properties, Notification Area, then to Systems Icons, the Volume Control icon is grayed out and cannot be checked off.
    How can I reinstall the Volume Control icon on the taskbar?
    Thanks.:confused:
  2. 2007/07/12
    charlesvar
    charlesvar Inactive Alumni
    Hello rocketpilot and welcome to the Board,
    change the Control Panel view to Classic.
    In the CP > Sounds > Playback > then highlight Speakers > Properties General tab.
    Is there an Icon for the speakers?
    Under Contoller Information > Properties does the system say the device is working properly?
    rocketpilot
    Hi Charles,
    Sorry for the delay in getting back. In following your instructions, the speakers are working properly. When I started my computer this morning, the volume control icon, along with the battery charging level indicator and the internet icon automatically appeared in the taskbar. I am completely baffled by the fact they would reappear for no reason. I had started my computer approximately six times since the problem happened, however, today, they reappeared.
    Should I get my computer EXCORSIZED?::confused:
    Again, many thanks for the reply, and if this should happen again, I will let you know. It appears there is much more to Vista than meets the eye.
    Steven
  5. 2007/07/13
    charlesvar
    Hi Steven,
    Glad the problem is gone, for now at least, and thanks for the report back :)
  6. 2007/07/13
    Yes, but keep it on a leash.:p
    The audio will have a "Control Panel ", which is a third party program that can "take control" of the audio system. It might be playing up.
    You should be able to uninstall it from Control Panel (classic view)-> Programs and Features and just reinstall it from the drivers CD or maybe check for an updated version (that doesn't need a leash :D ).
