Volume Control icon and taskbar
Discussion in 'Windows XP' started by wolfy810, 2005/02/20.
  1. 2005/02/20
    wolfy810
    wolfy810 Inactive Thread Starter
    When I try to place Volume Control in my task bar, I get an error message stating that "Windows cannot display the volume control on the taskbar because the Volume Control program has not been installed. To install it, use Add/Remove Programs in Control Panel. "
    Why am I getting this message when I can access volume control through control panel and it works just fine?
    wolfy810
  2. 2005/02/20
    wolfy810
    Nevermind, problem fixed
    I did not see similar posts prior to posting mine. My problem has been fixed. Thanks!
    loonychoons Lifetime Subscription
    loonychoons Inactive
    Volume control?
    I thought that I might just check? I went too Control Panal --Autio devices-- my Realtek AC97 gave me the option of an Icon on my taskbar? Hope that this helps Lenny Chowns
  5. 2005/02/20
    That was quick?
    I went to reply it took me just a couple of min. to answer.when I submited you had already fixed your problem Sorry?
