Windows Vista Vista start up problems - Corrupt Registry?
Discussion in 'Legacy Windows' started by Caveman, 2011/11/01.
  1. 2011/11/01
    Caveman
    Caveman Inactive Thread Starter
    Hoping someone can help here. My wife owns a Toshiba Satellite Laptop with Vista Home Premium installed. The other day the laptop went beep and shut down. Now it will not boot up - it gets the Toshiba screen then goes to a white flashing cursor in the top left. Pressing F8 does not open up the Recovery Console, I have downloaded a Recovery Console program and burnt it to a disc. I can select to boot from the DVD Drive and the Recovery console does open up.
    I have tried the Start Up Repair, but consistently encounter an error which reads 'The exception breakpoint: A breakpoint has been reached (0x80000003) occurred in the application at location 0x739c746a: Click ok to terminate.'
    It will then open a box stating that Windows cannot repair the problem. Under the details, it lists the following;
    Problem Signature 01 External Media
    Problem Signature 02 6.0.6000.16386.6.0.6001.18000
    Problem Signature 03 6
    Problem Signature 04 262148
    Problem Signature 05 Corrupt Registry
    Problem Signature 06 Corrupt Registry
    Problem Signature 07 32
    Problem Signature 08 3
    Problem Signature 09 Rollback Registry
    Problem Signature 10 32
    I have also ran chkdsk from the Command Prompt, but that has found no errors.
    There is no other back up disc and I don't have a copy of Vista with the laptop.
    Any advice will be welcome. Thanks in advance.
  2. 2011/11/05
    Corrupt Registry is the worst error I can imagine/deal with. Windows can't work without it.
    Me, I don't try "fixing" a corrupt registry, but you can try restoring from a previous backup.
    You can take the hard drive out of the laptop and connect it into another (desktop) computer. You can backup the data there and then go on to reinstall the Windows system afresh.
    Consider this if you can't find other suggestions.
    For taking backup, its not necessary to perform surgery on the laptop. Just download Ubuntu Live Version, burn it on a cd, boot from it & backup to a usb device.
  5. 2011/11/06
    Caveman
    Thank you Mattman & Rsinfo.
    I have considered reloading Windows and it does appear that is what will happen.
    Mattman: The F8 function does not work - I have a recovery disc that I have tried, but the System Restore function does not work as it says that there are no restore points that it can read from.
    Just one other question though, could this possibly be an indication of a failing hard drive?
  7. 2011/11/06
    Not necessarily. If you have doubts, download & run the hdd manufacturer's utility.
  8. 2011/11/07
    I would as well, BUT HDD manufacturer's utilities look for bad sectors, if they find them they say the hard drive is bad and it should be returned under warranty (if it is still under warranty).
    Windows Checkdisk (CHKDSK) can try to save data from bad sectors. Although you say "The F8 function does not work ", it is quite hard to "catch" at startup. It is between the BIOS screens and the Windows loading screens (you need to catch it before the OS starts loading). I start tap, tap, tapping the F8 key soon after the first screen appears.
    You can go to the section Safe mode with command prompt and run the command
    CHKDSK /r
    leave it to run as long as it likes (like overnight). Don't stop or crash out of it.
    If there are bad sectors in your registry files, CHKDSK might be able to recover them. If CHKDSK completes, your hard drive should have your data intact.
    I think it unlikely that the "corrupt registry" report relates to a bad HDD, but it could if there are bad sectors where the registry files are located on the hard drive.
  9. 2011/11/07
    Not really (or not always?). I have had bad sectors detected on a drive, and was never advised to return the drive. It takes more then just some bad sectors for the drive to be labeled 'failed' and the software to recommend you return the drive.
  10. 2011/11/07
    With modern multi gigbytes drives, its very common to have bad sectors. But the drive itself remaps & locks these bad sectors. The trouble starts when the drive runs out of the secors that can be allocated for mapping. If the software detects such a condition, it may suggest that you return the drive.
  11. 2011/11/08
    You are probably right guys. What I find though, is that the utilities can find problems like bad sectors, but can't fix them. I have run CHKDSK after the utilities and the drive is working again.
    As far as I know though, if you have bad sectors they will only get worse, it is damage to the surface of the disks.
    rsinfo, I don't know or haven't heard, that the the drive re-maps itself. I expect CHKDSK does it from my research.
  12. 2011/11/08
  13. 2011/11/11
    Caveman
    Gentlemen, this has been a fascinating discussion! I have resolved the problem by re-installing Vista and the laptop is now working well. Thank you for the info.
  14. 2011/11/12
    Thanks for letting us know. That is the option I use without much hesitation if I suspect the registry is corrupted. I would still test and check the HDD though.
    Please mark the thread Resolved.
