virus and xp problems
Discussion in 'Windows XP' started by zumakat, 2007/07/25.
  1. 2007/07/25
    zumakat
    zumakat Inactive Thread Starter
    my son's computer has become infected, i want to 'scrub' the hard drive and start anew, since i have no restore points available, also, can't get add/remove programs to work, have put in xp disk, but get to where to partition and then told not recommended to duplicate operating system, what do i need to do to just start from scratch?
  2. 2007/07/25
    mickzer
    mickzer Well-Known Member
    Or my notes on this .....
  5. 2007/07/26
    visionof
    visionof Inactive
    First make sure that you have the instal or restore disks and key code
    If there is anything serious you have- data copy it to an external hard drive or back up onto dvd/ or cds
    If you want to be really safe use norton ghost to backup the entire hard drive onto another hard drive or dvds
    to install windows best to go from scratch
    if you update the windows it causes nothing but trouble in xp
    can wipe out your documents and desktop
    seems sometimes to save old os - takes space
    the steps are to be sure
    1) format the hard drive
    you can do this with a bootable windows 98 diskette ( if you have a diskette reader)
    you can go to bootdisk.com to create a diskette or boot cd
    Boot from that ( you may have to change boot order in the bios) to make the diskette or cd first order
    at the worst choose to restore to factory defaults >ok > save
    if not go to the manufacturer of the drive - maxtor , seagate, western digital and find a program to wipe out the hard drive
    it will write 1 and 0s to the drive
    It will take some time but you will be sure everything of that virus or spyware will be gone
    if you cannot go to www.killdisk.com and download the free program
    again it will take some time
    then boot off of the install or restore cd
    if it is not bootable there are links to msoft for a program from them to create bootable diskettes or a cd
    Have fun
    It never hurts to be oversafe
