virtual hardware question
Discussion in 'PC Hardware' started by BladeTurbo, 2004/05/27.
  1. 2004/05/27
    BladeTurbo
    BladeTurbo Inactive Thread Starter
    Hi All, i currently use Alcohol 120% and was wondering if they have a program like that which emulates a floppy drive?
  2. 2004/05/27
    BladeTurbo
    sparrow
    sparrow Inactive
    Addition?
    Check out Incd by Ahead; I checked the alcohol120% manual and I can't see anything similar.
  6. 2004/06/01
    BladeTurbo, your response with further info and Sparrow's reply made me think again. You want an "image" type file for the floppies. Could try an achiving program like Winzip. Highlight the files on the floppy, right-click and select "Add to zip ". Make a zip file of each. When you want to use them unzip to a floppy or somewhere for those emulators (I mentioned) to use from your harddrive.
    Edit: Burn the zipped files onto a CD? Should fit several hundred :)
