vid card differences
Discussion in 'PC Hardware' started by Aku, 2005/02/04.
  1. 2005/02/04
    Aku
    Aku Inactive Thread Starter
    Aku,
  2. 2005/02/05
    Hi Aku(Matt),
    The 9600 is set to run at core speed 325Mhz, memory 400Mhz
    The 9600PRO is set to 400Mhz and 600Mhz
    The PRO has a little more technology (Truform 2.0)
    A "downside" to the PRO may be that seems to run OpenGL 1.5, the 9600 runs OpenGL 2.0 :confused:
    You can see the 9600 has a heatsink, the PRO has a fan.
    I would actually go for the 9600PRO "retail ":
    http://www.newegg.com/app/viewproductdesc.asp?description=14-102-409&DEPA=0
    Although you don't get the extra RAM (you should not miss it anyway), it will come properly packaged. You see quite a few reviews of bulk OEM products not arriving in great condition.
    Aku
    Thanks. I decided to go with the Pro. i have a freind whose brother has the 9600 Pro n it runs all the games I mentioned great. i should have the money soon, and i found one on clearence for $80 so i can get RAM and the video card.
    Aku,
