Solved Very slow PC and Wireless disconnecting
Discussion in 'Malware and Virus Removal Archive' started by thierry1, 2009/05/30.
  1. 2009/05/30
    thierry1
    thierry1 Inactive Thread Starter
    [Resolved] Very slow PC and Wireless disconnecting
    Hi guys, unfortunately not the first time I've posted on Windows BBS, my PC seems to have piked up a problem with slow performance, for an example the DDS logs took over 30 minutes to generate from download to the text files being displayed.
    I also have an problem where my wireless internet disconnects at intervals when I'm using the internet. If I try to 'disable' or 'repair' the problem the screen gets stuck. The wireless cannot be reconnected until the PC is rebooted. A reboot usually takes around 15 minutes. It's proving to be very frustrating.
    I have lots of the applications from previous problems, like MBAM, but it's not picking up anything malicious, neither is a full Norton and Windows Defender scan, so I'm not sure what's causing the slow performance, and in particular, the wireless network to disconnect.
    I have a second PC which uses the wireless network fine, so it's not a problem with that. The symbol in the system tray in my PC also shows that a signal from the wireless is detected, but when I try using the internet it displays a 'page cannot be found' screen which I can't get round other that with a reboot, it's the same in Firefox as it is in IE.
    I've posted my two DDS logs below.
    Thank you for your assistance
    DDS (Ver_09-05-14.01) - NTFSx86
    Run by user user at 12:28:36.42 on 30/05/2009
    Internet Explorer: 7.0.5730.11 BrowserJavaVersion: 1.6.0_13
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.510.134 [GMT 1:00]
    AV: Norton Internet Security *On-access scanning disabled* (Outdated) {E10A9785-9598-4754-B552-92431C1C35F8}
    FW: Norton Internet Security *disabled* {7C21A4C9-F61F-4AC4-B722-A6E19C16F220}
    C:\WINDOWS\system32\svchost -k DcomLaunch
    svchost.exe
    C:\Program Files\Windows Defender\MsMpEng.exe
    C:\WINDOWS\System32\svchost.exe -k netsvcs
    C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
    C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
    svchost.exe
    svchost.exe
    C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
    C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
    C:\Program Files\Norton Internet Security\ISSVC.exe
    C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
    svchost.exe
    C:\Program Files\Adobe\Photoshop Elements 3.0\PhotoshopElementsFileAgent.exe
    C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    C:\Program Files\Bonjour\mDNSResponder.exe
    C:\Program Files\Microsoft SQL Server\MSSQL$VAIO_VEDB\Binn\sqlservr.exe
    C:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
    C:\WINDOWS\system32\nvsvc32.exe
    C:\Program Files\Adobe\Photoshop Elements 3.0\PhotoshopElementsDeviceConnect.exe
    C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
    C:\WINDOWS\system32\svchost.exe -k imgsvc
    C:\Program Files\Sony\VAIO Event Service\VESMgr.exe
    C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VCSW\VCSW.exe
    C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzCdbSvc.exe
    C:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
    C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzFw.exe
    C:\WINDOWS\System32\svchost.exe -k HTTPFilter
    C:\Program Files\Apoint\Apoint.exe
    C:\WINDOWS\system32\ICO.EXE
    C:\Program Files\Sony\VAIO Power Management\SPMgr.exe
    C:\Program Files\Sony\ISB Utility\ISBMgr.exe
    C:\Program Files\Sony\VAIO Update 2\VAIOUpdt.exe
    C:\PROGRA~1\Sony\SONICS~1\SsAAD.exe
    C:\Program Files\Apoint\Apntex.exe
    C:\Program Files\Common Files\Sony Shared\AVLib\SSScsiSV.exe
    C:\Program Files\Java\jre6\bin\jusched.exe
    C:\Program Files\Mozilla Firefox\firefox.exe
    C:\Documents and Settings\user user\Desktop\dds.scr
    uStart Page = hxxp://www.google.co.uk/
    uInternet Settings,ProxyOverride = <local>;*.local
    BHO: Adobe PDF Reader Link Helper: {06849e9f-c8d7-4d59-b87d-784b7d6be0b3} - c:\program files\adobe\acrobat 7.0\activex\AcroIEHelper.dll
    BHO: CNisExtBho Class: {9ecb9560-04f9-4bbc-943d-298ddf1699e1} - c:\program files\common files\symantec shared\adblocking\NISShExt.dll
    BHO: CNavExtBho Class: {bdf3e430-b101-42ad-a544-fadc6b084872} - c:\program files\norton internet security\norton antivirus\NavShExt.dll
    BHO: Java(tm) Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - c:\program files\java\jre6\bin\jp2ssv.dll
    BHO: JQSIEStartDetectorImpl Class: {e7e6f031-17ce-4c07-bc86-eabfe594f69c} - c:\program files\java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    TB: Norton Internet Security: {0b53eac3-8d69-4b9e-9b19-a37c9a5676a7} - c:\program files\common files\symantec shared\adblocking\NISShExt.dll
    TB: Norton AntiVirus: {42cdd1bf-3ffb-4238-8ad1-7859df00b1d6} - c:\program files\norton internet security\norton antivirus\NavShExt.dll
    TB: &Google: {2318c2b1-4965-11d4-9b18-009027a5cd4f} -
    TB: {E97B5F2E-CA8E-4D34-BDA3-44EEC4ED2B12} - No File
    uRun: [ctfmon.exe] c:\windows\system32\ctfmon.exe
    mRun: [Apoint] c:\program files\apoint\Apoint.exe
    mRun: [Mouse Suite 98 Daemon] ICO.EXE
    mRun: [SonyPowerCfg] c:\program files\sony\vaio power management\SPMgr.exe
    mRun: [ISBMgr.exe] c:\program files\sony\isb utility\ISBMgr.exe
    mRun: [VAIO Update 2] "c:\program files\sony\vaio update 2\VAIOUpdt.exe" /Stationary
    mRun: [ccApp] "c:\program files\common files\symantec shared\ccApp.exe "
    mRun: [Symantec NetDriver Monitor] c:\progra~1\symnet~1\SNDMon.exe /Consumer
    mRun: [SsAAD.exe] c:\progra~1\sony\sonics~1\SsAAD.exe
    mRun: [NvCplDaemon] //~rundll32.exe c:\windows\system32\nvcpl.dll,nvstartup
    mRun: [LXCCCATS] rundll32 c:\windows\system32\spool\drivers\w32x86\3\LXCCtime.dll,_RunDLLEntry@16
    mRun: [FaxCenterServer] "c:\program files\lexmark fax solutions\fm3032.exe" /s
    mRun: [SunJavaUpdateSched] "c:\program files\java\jre6\bin\jusched.exe "
    dRun: [CTFMON.EXE] c:\windows\system32\CTFMON.EXE
    IE: &Translate English Word - c:\program files\google\GoogleToolbar2.dll/cmwordtrans.html
    IE: Backward Links - c:\program files\google\GoogleToolbar2.dll/cmbacklinks.html
    IE: E&xport to Microsoft Excel - c:\progra~1\micros~4\office11\EXCEL.EXE/3000
    IE: Similar Pages - c:\program files\google\GoogleToolbar2.dll/cmsimilar.html
    IE: Translate Page into English - c:\program files\google\GoogleToolbar2.dll/cmtrans.html
    Trusted Zone: sony-europe.com
    Trusted Zone: sonystyle-europe.com
    Trusted Zone: vaio-link.com
    DPF: {00B71CFB-6864-4346-A978-C0A14556272C} - hxxp://messenger.zone.msn.com/binary/msgrchkr.cab31267.cab
    DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} - hxxp://upload.facebook.com/controls/FacebookPhotoUploader5.cab
    DPF: {2D8ED06D-3C30-438B-96AE-4D110FDC1FB8} - hxxp://acs.pandasoftware.com/activescan/cabs/as2stubie.cab
    DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_13-windows-i586.cab
    DPF: {8D9563A9-8D5F-459B-87F2-BA842255CB9A} - hxxps://myconnect.bbc.co.uk/InternalSite/WhlCompMgr.cab
    DPF: {8E0D4DE5-3180-4024-A327-4DFAD1796A8D} - hxxp://messenger.zone.msn.com/binary/MessengerStatsClient.cab31267.cab
    DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} - hxxp://fpdownload.macromedia.com/get/flashplayer/current/polarbear/ultrashim.cab
    DPF: {9A9307A0-7DA4-4DAF-B042-5009F29E09E1} - hxxp://acs.pandasoftware.com/activescan/as5free/asinst.cab
    DPF: {CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_13-windows-i586.cab
    DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_13-windows-i586.cab
    DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} - hxxp://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
    DPF: {F6BF0D00-0B2A-4A75-BF7B-F385591623AF} - hxxp://messenger.zone.msn.com/binary/SolitaireShowdown.cab31267.cab
    DPF: {F7EDBBEA-1AD2-4EBF-AA07-D453CC29EE65} - hxxps://plugins.valueactive.eu/flashax/iefax.cab
    Notify: !SASWinLogon - c:\program files\superantispyware\SASWINLO.dll
    Notify: igfxcui - igfxdev.dll
    SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - c:\windows\system32\WPDShServiceObj.dll
    SEH: SABShellExecuteHook Class: {5ae067d3-9afb-48e0-853a-ebb7f4a000da} - c:\program files\superantispyware\SASSEH.DLL
    SEH: Microsoft AntiMalware ShellExecuteHook: {091eb208-39dd-417d-a5dd-7e2c2d8fb9cb} - c:\progra~1\wifd1f~1\MpShHook.dll
    ================= FIREFOX ===================
    FF - ProfilePath - c:\docume~1\rabind~1\applic~1\mozilla\firefox\profiles\9h1aav5x.default\
    FF - prefs.js: browser.startup.homepage - hxxp://www.google.co.uk
    FF - plugin: c:\documents and settings\user user\application data\mozilla\firefox\profiles\9h1aav5x.default\extensions\npfax@microgaming.co.uk\platform\winnt_x86-msvc\plugins\npfax.dll
    R0 pavboot;pavboot;c:\windows\system32\drivers\pavboot.sys [2009-3-31 28544]
    R1 PrivateDisk;PrivateDisk;c:\windows\system32\drivers\privatediskm.sys [2004-7-6 45627]
    R1 SASDIFSV;SASDIFSV;c:\program files\superantispyware\sasdifsv.sys [2009-3-23 9968]
    R1 SASKUTIL;SASKUTIL;c:\program files\superantispyware\SASKUTIL.SYS [2009-3-23 72944]
    R1 SAVRTPEL;SAVRTPEL;c:\program files\norton internet security\norton antivirus\SAVRTPEL.SYS [2005-2-5 53896]
    R2 AdobeActiveFileMonitor;Adobe Active File Monitor;c:\program files\adobe\photoshop elements 3.0\PhotoshopElementsFileAgent.exe [2004-10-4 98304]
    R2 ccEvtMgr;Symantec Event Manager;c:\program files\common files\symantec shared\CCEVTMGR.EXE [2005-3-5 185704]
    R2 ccProxy;Symantec Network Proxy;c:\program files\common files\symantec shared\CCPROXY.EXE [2005-3-5 239264]
    R2 ccSetMgr;Symantec Settings Manager;c:\program files\common files\symantec shared\CCSETMGR.EXE [2005-3-5 177512]
    R2 MSSQL$VAIO_VEDB;MSSQL$VAIO_VEDB;c:\program files\microsoft sql server\mssql$vaio_vedb\binn\sqlservr.exe -svaio_vedb --> c:\program files\microsoft sql server\mssql$vaio_vedb\binn\sqlservr.exe -sVAIO_VEDB [?]
    R2 PhotoshopElementsDeviceConnect;Photoshop Elements Device Connect;c:\program files\adobe\photoshop elements 3.0\PhotoshopElementsDeviceConnect.exe [2004-10-4 118784]
    R2 WinDefend;Windows Defender;c:\program files\windows defender\MsMpEng.exe [2006-11-3 13592]
    R3 navapsvc;Norton AntiVirus Auto-Protect Service;c:\program files\norton internet security\norton antivirus\NAVAPSVC.exe [2005-3-25 128160]
    R3 NAVENG;NAVENG;c:\progra~1\common~1\symant~1\virusd~1\20051230.004\NAVENG.Sys [2006-1-1 77864]
    R3 NAVEX15;NAVEX15;c:\progra~1\common~1\symant~1\virusd~1\20051230.004\NavEx15.Sys [2006-1-1 750952]
    R3 SAVRT;SAVRT;c:\program files\norton internet security\norton antivirus\SAVRT.SYS [2005-2-5 334984]
    S2 SBService;ScriptBlocking Service;c:\progra~1\common~1\symant~1\script~1\SBServ.exe [2005-3-24 67184]
    S3 ccPwdSvc;Symantec Password Validation;c:\program files\common files\symantec shared\CCPWDSVC.EXE [2005-3-5 83304]
    S3 getPlus(R) Helper;getPlus(R) Helper;c:\program files\nos\bin\getPlus_HelperSvc.exe [2009-4-14 33176]
    S3 SASENUM;SASENUM;c:\program files\superantispyware\SASENUM.SYS [2009-3-23 7408]
    S3 SAVScan;SAVScan;c:\program files\norton internet security\norton antivirus\SAVSCAN.EXE [2005-2-18 198368]
    S3 SQLAgent$VAIO_VEDB;SQLAgent$VAIO_VEDB;c:\program files\microsoft sql server\mssql$vaio_vedb\binn\sqlagent.exe -i vaio_vedb --> c:\program files\microsoft sql server\mssql$vaio_vedb\binn\sqlagent.EXE -i VAIO_VEDB [?]
    2009-05-24 23:31 0 a------- c:\windows\system32\w32apiw.dll
    2009-05-24 14:04 <DIR> --d----- c:\windows\system32\CatRoot2
    2009-05-23 15:30 73,728 a------- c:\windows\system32\javacpl.cpl
    2009-05-21 11:17 <DIR> --d----- C:\HostsXpert
    2009-05-21 10:38 <DIR> --d----- C:\_OTMoveIt
    2009-05-20 23:41 130,048 a------- c:\windows\PEV.exe
    2009-05-23 15:30 410,984 a------- c:\windows\system32\deploytk.dll
    2009-05-23 12:36 12,800 a------- c:\program files\hijackthis.log
    2009-04-06 15:32 38,496 a------- c:\windows\system32\drivers\mbamswissarmy.sys
    2009-04-06 15:32 15,504 a------- c:\windows\system32\drivers\mbam.sys
    2009-04-02 10:34 1,878,888 a------- C:\install_flash_player.exe
    2009-03-31 13:54 175,504 a------- C:\activescan2_en.exe
    2009-03-29 15:41 353,485 a------- C:\HostsXpert.zip
    2009-03-26 16:07 62,729,728 a------- C:\avg_free_stf_en_85_283a1450.exe
    2009-03-25 13:41 1,339,834 a------- C:\MGtools.exe
    2009-03-06 15:22 284,160 a------- c:\windows\system32\pdh.dll
    2009-03-03 01:18 826,368 a------- c:\windows\system32\wininet.dll
    2008-12-21 15:21 7,590,400 a------- c:\program files\ica32web.msi
    2008-12-12 20:29 186 a------- c:\docume~1\rabind~1\applic~1\wklnhst.dat
    2008-06-15 13:27 59,839,784 a------- c:\program files\iTunesSetup.exe
    2008-04-10 22:17 1,495,112 a------- c:\program files\install_flash_player.exe
    2007-07-22 16:59 41,384 a------- c:\program files\basiccms.zip
    2007-07-22 16:43 22,312,757 a------- c:\program files\wamp5_1.7.2.exe
    2007-07-21 18:38 1,126 a------- c:\docume~1\rabind~1\applic~1\filterclsid.dat
    2007-01-01 16:28 4,308,596 a------- c:\program files\BitTornado-0.3.17-w32install.exe
    2006-12-29 17:19 899,414 a------- c:\program files\DVDDecrypter_3.5.4.0.exe
    2006-12-28 21:01 734,160 a------- c:\program files\VobSub_2.23.exe
    2006-12-20 21:59 9,918,872 a------- c:\program files\WMEncoder.exe
    2006-12-20 21:52 878,896 a------- c:\program files\WGAPluginInstall.exe
    2006-12-20 16:13 4,865,728 a------- c:\program files\rminstall.exe
    2006-12-19 14:14 1,035,271 a------- c:\program files\wrar362.exe
    2006-12-02 15:16 1,480,862 a------- c:\program files\aresregular196_installer.exe
    2006-12-02 15:15 1,480,862 a------- c:\program files\Ares.exe
    2005-02-16 12:06 218,112 a------- c:\program files\HijackThis.exe
    2005-07-14 13:31 27,648 a--shr-- c:\windows\system32\AVSredirect.dll
    2005-06-26 16:32 616,448 a--shr-- c:\windows\system32\cygwin1.dll
    2005-06-21 23:37 45,568 a--shr-- c:\windows\system32\cygz.dll
    2006-05-03 10:06 163,328 ---shr-- c:\windows\system32\flvDX.dll
    2004-01-25 01:00 70,656 a--shr-- c:\windows\system32\i420vfw.dll
    2007-02-21 11:47 31,232 ---shr-- c:\windows\system32\msfDX.dll
    2008-12-24 13:01 32,768 a--sh--- c:\windows\system32\config\systemprofile\local settings\history\history.ie5\mshist012008122420081225\index.dat
    ============= FINISH: 12:29:40.90 ===============
    UNLESS SPECIFICALLY INSTRUCTED, DO NOT POST THIS LOG.
    IF REQUESTED, ZIP IT UP & ATTACH IT
    Boot Device: \Device\HarddiskVolume2
    Install Date: 20/11/2005 17:09:51
    System Uptime: 30/05/2009 11:22:01 (1 hours ago)
    Processor: Intel(R) Pentium(R) M processor 1.73GHz | N/A | 1729/133mhz
    ==== Disk Partitions =========================
    C: is FIXED (NTFS) - 33 GiB total, 11.288 GiB free.
    D: is FIXED (NTFS) - 35 GiB total, 9.409 GiB free.
    E: is Removable
    F: is CDROM ()
    G: is CDROM ()
    ==== Disabled Device Manager Items =============
    ==== System Restore Points ===================
    RP598: 16/04/2009 02:50:34 - Software Distribution Service 3.0
    RP599: 17/04/2009 22:45:20 - System Checkpoint
    RP600: 18/04/2009 01:30:10 - Software Distribution Service 3.0
    RP601: 19/04/2009 00:37:55 - Removed Windows Live Upload Tool
    RP602: 19/04/2009 00:38:25 - Removed Windows Live Sign-in Assistant
    RP603: 20/04/2009 15:51:20 - Software Distribution Service 3.0
    RP604: 22/04/2009 16:33:46 - System Checkpoint
    RP605: 23/04/2009 19:56:15 - Software Distribution Service 3.0
    RP606: 25/04/2009 16:09:45 - System Checkpoint
    RP607: 26/04/2009 18:31:08 - System Checkpoint
    RP608: 27/04/2009 22:26:31 - System Checkpoint
    RP609: 28/04/2009 10:47:52 - Software Distribution Service 3.0
    RP610: 29/04/2009 14:26:43 - System Checkpoint
    RP611: 29/04/2009 19:25:32 - Software Distribution Service 3.0
    RP612: 30/04/2009 21:17:07 - System Checkpoint
    RP613: 01/05/2009 11:07:07 - Software Distribution Service 3.0
    RP614: 03/05/2009 22:16:28 - System Checkpoint
    RP615: 04/05/2009 22:18:04 - System Checkpoint
    RP616: 05/05/2009 22:49:29 - System Checkpoint
    RP617: 06/05/2009 11:43:08 - Software Distribution Service 3.0
    RP618: 07/05/2009 14:19:19 - System Checkpoint
    RP619: 08/05/2009 11:55:16 - Software Distribution Service 3.0
    RP620: 10/05/2009 19:19:00 - System Checkpoint
    RP621: 11/05/2009 21:12:33 - System Checkpoint
    RP622: 12/05/2009 10:21:43 - Software Distribution Service 3.0
    RP623: 13/05/2009 12:58:30 - System Checkpoint
    RP624: 13/05/2009 13:21:24 - Software Distribution Service 3.0
    RP625: 14/05/2009 14:15:55 - System Checkpoint
    RP626: 15/05/2009 10:56:01 - Software Distribution Service 3.0
    RP627: 16/05/2009 14:44:19 - System Checkpoint
    RP628: 17/05/2009 18:20:15 - System Checkpoint
    RP629: 18/05/2009 15:11:03 - Software Distribution Service 3.0
    RP630: 19/05/2009 15:21:31 - System Checkpoint
    RP631: 20/05/2009 22:37:31 - System Checkpoint
    RP632: 22/05/2009 10:19:57 - Software Distribution Service 3.0
    RP633: 23/05/2009 14:36:42 - System Checkpoint
    RP634: 23/05/2009 15:27:59 - Removed Java(TM) 6 Update 13
    RP635: 23/05/2009 15:30:09 - Installed Java(TM) 6 Update 13
    RP636: 24/05/2009 17:17:45 - System Checkpoint
    RP637: 25/05/2009 15:57:44 - Software Distribution Service 3.0
    RP638: 30/05/2009 12:23:57 - Software Distribution Service 3.0
    ==== Installed Programs ======================
    Adobe Acrobat 7.0 Elements
    Adobe Flash Player 10 ActiveX
    Adobe Flash Player 10 Plugin
    Adobe Photoshop Elements 3.0
    Adobe Premiere Standard
    Adobe Reader 7.1.0
    Apple Mobile Device Support
    Apple Software Update
    Ares 1.9.6
    BitTornado 0.3.17
    Bonjour
    CC_ccProxyExt
    ccCommon
    CCleaner (remove only)
    ccPxyCore
    Citrix Presentation Server Client
    Click to DVD 2.0.03 Menu Data
    Click to DVD 2.4.10
    Compatibility Pack for the 2007 Office system
    Critical Update for Windows Media Player 11 (KB959772)
    Cucusoft MPEG/MOV/RM/DivX/AVI to DVD/VCD/SVCD Creator Pro 7.07
    DAEMON Tools
    DivxToDVD 1.99.20b
    DVD Decrypter (Remove Only)
    DVD Shrink 3.2
    DVgate Plus
    FileZilla Client 3.1.6
    Football Manager 2006
    Google Earth
    HDAUDIO SoftV92 Data Fax Modem with SmartCP
    HijackThis 1.99.1
    Hotfix for Windows Internet Explorer 7 (KB947864)
    Image Converter 2
    Intel(R) Graphics Media Accelerator Driver for Mobile
    Intel(R) PRO Network Connections Drivers
    Intel(R) PROSet/Wireless Software
    InterVideo WinDVD for VAIO
    InterVideo WinDVDX
    iPod for Windows 2005-09-23
    iTunes
    K-Lite Codec Pack 3.2.5 Standard
    Kazaa 3.2.2
    LAN-Express AS IEEE 802.11 Wireless LAN
    Lexmark 3300 Series
    Lexmark Fax Solutions
    LiveReg (Symantec Corporation)
    LiveUpdate 2.6 (Symantec Corporation)
    Macromedia Dreamweaver 8
    Macromedia Dreamweaver MX
    Macromedia Extension Manager
    Macromedia Fireworks MX
    Macromedia Flash MX
    Macromedia Flash Player
    Malwarebytes' Anti-Malware
    Malwarebytes' RogueRemover
    mCore
    mDriver
    Memory Stick Formatter
    Microsoft .NET Framework 2.0
    Microsoft Application Error Reporting
    Microsoft Compression Client Pack 1.0 for Windows XP
    Microsoft Internationalized Domain Names Mitigation APIs
    Microsoft National Language Support Downlevel APIs
    Microsoft Office Professional Edition 2003
    Microsoft SQL Server Desktop Engine (VAIO_VEDB)
    Microsoft User-Mode Driver Framework Feature Pack 1.0
    Microsoft Visual C++ 2005 Redistributable
    Microsoft Works
    mMHouse
    MoodLogic
    Mozilla Firefox (3.0.10)
    mPfMgr
    mProSafe
    MSRedist
    MSXML 4.0 SP2 (KB927978)
    MSXML 4.0 SP2 (KB936181)
    MSXML 4.0 SP2 (KB954430)
    mWlsSafe
    mXML
    nCleaner second 2.3.4.0
    Nero 7 Ultra Edition
    Nokia Connectivity Cable Driver
    Norton AntiSpam
    Norton AntiVirus 2005
    Norton Internet Security 2005 (Symantec Corporation)
    Norton Security Center
    Norton WMI Update
    NVIDIA Drivers
    OpenMG Secure Module 4.2.00
    Orange Livebox
    Panda ActiveScan
    Panda ActiveScan 2.0
    Pcast P2P Ã÷ýÌå¿Ã˜¼Ã¾ 1.0.0.17
    PictureGear Studio 2.0
    QuickTime
    RealPlayer
    Realtek High Definition Audio Driver
    Roxio DigitalMedia Audio
    Roxio DigitalMedia Copy
    Roxio DigitalMedia Data
    Runtime 8.0 Libraries
    SafeGuard® PrivateDisk 1.00.6 - Try and Buy Version
    SAMSUNG CDMA Modem Driver Set
    SAMSUNG Mobile Composite Device Software
    Samsung Mobile phone USB driver Software
    SAMSUNG Mobile USB Modem 1.0 Software
    SAMSUNG Mobile USB Modem Software
    Samsung PC Studio
    Samsung PC Studio 3 USB Driver Installer
    Security Update for CAPICOM (KB931906)
    Security Update for Windows Internet Explorer 7 (KB928090)
    Security Update for Windows Internet Explorer 7 (KB929969)
    Security Update for Windows Internet Explorer 7 (KB931768)
    Security Update for Windows Internet Explorer 7 (KB933566)
    Security Update for Windows Internet Explorer 7 (KB937143)
    Security Update for Windows Internet Explorer 7 (KB938127)
    Security Update for Windows Internet Explorer 7 (KB939653)
    Security Update for Windows Internet Explorer 7 (KB942615)
    Security Update for Windows Internet Explorer 7 (KB944533)
    Security Update for Windows Internet Explorer 7 (KB950759)
    Security Update for Windows Internet Explorer 7 (KB953838)
    Security Update for Windows Internet Explorer 7 (KB956390)
    Security Update for Windows Internet Explorer 7 (KB958215)
    Security Update for Windows Internet Explorer 7 (KB960714)
    Security Update for Windows Internet Explorer 7 (KB961260)
    Security Update for Windows Internet Explorer 7 (KB963027)
    Security Update for Windows XP (KB923561)
    Security Update for Windows XP (KB938464-v2)
    Security Update for Windows XP (KB938464)
    Security Update for Windows XP (KB952004)
    Security Update for Windows XP (KB954459)
    Security Update for Windows XP (KB956572)
    Security Update for Windows XP (KB958687)
    Security Update for Windows XP (KB958690)
    Security Update for Windows XP (KB959426)
    Security Update for Windows XP (KB960225)
    Security Update for Windows XP (KB960715)
    Security Update for Windows XP (KB960803)
    Security Update for Windows XP (KB961373)
    Setting Utility Series
    SonicStage 3.2
    SonicStage Mastering Studio 1.4
    SonicStage Mastering Studio Audio Filter
    SonicStage Mastering Studio Audio Filter Custom Preset
    SonicStage Mastering Studio Plugins
    Sony MP4 Shared Library
    Sony Utilities DLL
    Sony Video Shared Library
    SopCast 2.0.4
    SPBBC
    Spybot - Search & Destroy
    Spybot - Search & Destroy 1.4
    SUPER © Version 2007.bld.23 (July 4, 2007)
    SUPERAntiSpyware Free Edition
    Symantec Network Drivers Update
    Symantec Script Blocking Installer
    SymNet
    TomTom HOME
    TVAnts 1.0
    TVUPlayer 2.3.2.52
    Update for Windows XP (KB951978)
    Update for Windows XP (KB967715)
    VAIO Control Center
    VAIO Edit Components
    VAIO Event Service
    VAIO Light Flo Wallpaper
    VAIO Long Battery Life Wallpaper
    VAIO Media 4.0
    VAIO Media AC3 Decoder 1.0
    VAIO Media Integrated Server 4.2
    VAIO Media Redistribution 4.0
    VAIO Media Registration Tool 4.0
    VAIO Online Registration (English)
    VAIO Original Screen Saver
    VAIO Original Screen Saver VAIO Motion HD Normal Contents
    VAIO Original Screen Saver VAIO Motion HD Wide Contents
    VAIO Original Screen Saver VAIO Motion SD Normal Contents
    VAIO Original Screen Saver VAIO Motion SD Wide Contents
    VAIO Original Screen Saver VAIO Scene HD Normal Contents
    VAIO Original Screen Saver VAIO Scene HD Wide Contents
    VAIO Original Screen Saver VAIO Scene SD Normal Contents
    VAIO Original Screen Saver VAIO Scene SD Wide Contents
    VAIO Product Survey
    VAIO Update 2
    VC_MergeModuleToMSI
    VOR
    VPS
    WebFldrs XP
    Whale Communications' Client Components v3.6
    Windows Defender
    Windows Genuine Advantage Notifications (KB905474)
    Windows Media Encoder 9 Series
    Windows Media Format 11 runtime
    Windows XP Service Pack 3
    WinRAR archiver
    Wireless LAN Starter
    ==== Event Viewer Messages From Past Week ========
    30/05/2009 12:02:14, error: Service Control Manager [7011] - Timeout (30000 milliseconds) waiting for a transaction response from the stisvc service.
    24/05/2009 23:23:26, error: Service Control Manager [7034] - The VAIO Event Service service terminated unexpectedly. It has done this 1 time(s).
    24/05/2009 22:14:06, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the PEVSystemStart service to connect.
    24/05/2009 21:55:18, error: System Error [1003] - Error code 100000d1, parameter1 30000014, parameter2 00000002, parameter3 00000000, parameter4 f529c3c0.
    24/05/2009 21:53:01, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the IMAPI CD-Burning COM Service service to connect.
    24/05/2009 21:53:01, error: Service Control Manager [7000] - The IMAPI CD-Burning COM Service service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
    24/05/2009 21:35:48, error: Service Control Manager [7034] - The Symantec Settings Manager service terminated unexpectedly. It has done this 1 time(s).
    23/05/2009 17:15:05, error: Service Control Manager [7011] - Timeout (30000 milliseconds) waiting for a transaction response from the NVSvc service.
    23/05/2009 16:23:20, error: Service Control Manager [7011] - Timeout (30000 milliseconds) waiting for a transaction response from the VAIO Event Service service.
    23/05/2009 15:28:43, error: Service Control Manager [7023] - The Application Management service terminated with the following error: The specified module could not be found.
    23/05/2009 15:14:05, error: Service Control Manager [7022] - The VAIO Entertainment File Import Service service hung on starting.
    23/05/2009 14:58:38, error: Service Control Manager [7031] - The Windows Defender service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 15000 milliseconds: Restart the service.
    23/05/2009 14:58:24, error: Service Control Manager [7034] - The VAIO Entertainment Database Service service terminated unexpectedly. It has done this 1 time(s).
    23/05/2009 14:45:26, error: Service Control Manager [7023] - The Windows Firewall/Internet Connection Sharing (ICS) service terminated with the following error: Access is denied.
    23/05/2009 14:44:30, error: Service Control Manager [7032] - The Service Control Manager tried to take a corrective action (Restart the service) after the unexpected termination of the Windows Management Instrumentation service, but this action failed with the following error: An instance of the service is already running.
    23/05/2009 14:19:56, error: DCOM [10000] - Unable to start a DCOM Server: {FB7199AB-79BF-11D2-8D94-0000F875C541}. The error: "%3" Happened while starting this command: "C:\Program Files\Messenger\msmsgs.exe" -Embedding
    23/05/2009 12:29:56, error: Service Control Manager [7034] - The Symantec Network Proxy service terminated unexpectedly. It has done this 1 time(s).
    23/05/2009 11:57:32, error: Service Control Manager [7034] - The VAIO Entertainment File Import Service service terminated unexpectedly. It has done this 1 time(s).
    23/05/2009 11:57:27, error: Service Control Manager [7034] - The Windows Defender service terminated unexpectedly. It has done this 3 time(s).
    23/05/2009 11:56:58, error: Service Control Manager [7031] - The Windows Defender service terminated unexpectedly. It has done this 2 time(s). The following corrective action will be taken in 15000 milliseconds: Restart the service.
    23/05/2009 11:55:40, error: Service Control Manager [7034] - The ISSVC service terminated unexpectedly. It has done this 1 time(s).
    23/05/2009 11:48:03, error: Service Control Manager [7000] - The Application Layer Gateway Service service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
    23/05/2009 11:47:54, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the Application Layer Gateway Service service to connect.
    ==== End Of File ===========================
  2. 2009/05/31
    From your description, and DDS log, it doesn't look like security problem, but let's double check.
    **Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**
    2. Close any open browsers.
      • Click on this link to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      • Close any open browsers.
      • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
    6. Please post the "C:\ComboFix.txt" along with a new HijackThis log for further review.
    thierry1
    Hi Broni, thanks for the help.
    I ran the Combofix scan and the results, along with a HJT log is below:
    Combofix
    ComboFix 09-05-30.06 - user user 31/05/2009 16:36.8 - NTFSx86
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.510.69 [GMT 1:00]
    Running from: c:\documents and settings\user user\Desktop\ComboFix.exe
    ((((((((((((((((((((((((( Files Created from 2009-04-28 to 2009-05-31 )))))))))))))))))))))))))))))))
    2009-05-24 13:04 . 2009-05-31 15:36 -------- d-----w- c:\windows\system32\CatRoot2
    2009-05-23 15:23 . 2009-05-23 15:23 -------- d-----w- c:\documents and settings\Guest\Local Settings\Application Data\Mozilla
    2009-05-23 14:29 . 2009-05-23 14:29 152576 ----a-w- c:\documents and settings\user user\Application Data\Sun\Java\jre1.6.0_13\lzma.dll
    2009-05-21 10:17 . 2009-05-21 10:18 -------- d-----w- C:\HostsXpert
    2009-05-21 09:38 . 2009-05-21 09:38 -------- d-----w- C:\_OTMoveIt
    2009-05-30 11:09 . 2005-07-11 16:37 -------- d-----w- c:\program files\Common Files\Symantec Shared
    2009-05-23 14:30 . 2009-03-29 13:10 410984 ----a-w- c:\windows\system32\deploytk.dll
    2009-05-23 14:30 . 2005-07-11 16:29 -------- d-----w- c:\program files\Java
    2009-05-23 11:37 . 2005-11-29 20:21 -------- d-----w- c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
    2009-05-23 11:36 . 2009-03-25 11:25 12800 ----a-w- c:\program files\hijackthis.log
    2009-05-23 09:22 . 2008-01-20 18:00 -------- d-----w- c:\program files\Lx_cats
    2009-05-20 22:15 . 2006-12-24 11:52 -------- d-----w- c:\program files\backups
    2009-05-20 20:10 . 2009-03-25 10:29 117760 ----a-w- c:\documents and settings\user user\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\UIREPAIR.DLL
    2009-05-20 20:08 . 2007-12-08 01:20 -------- d-----w- c:\program files\SUPERAntiSpyware
    2009-04-30 13:44 . 2008-12-18 19:17 -------- d-----w- c:\documents and settings\user user\Application Data\FileZilla
    2009-04-14 12:57 . 2009-04-14 12:57 -------- d-----w- c:\documents and settings\All Users\Application Data\NOS
    2009-04-14 12:57 . 2009-04-14 12:57 -------- d-----w- c:\program files\NOS
    2009-04-10 15:15 . 2009-03-24 14:46 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
    2009-04-10 15:15 . 2009-03-30 22:19 2967799 ----a-w- c:\documents and settings\All Users\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\mbam-setup.exe
    2009-04-07 19:09 . 2005-11-20 17:10 77256 ----a-w- c:\documents and settings\user user\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
    2009-04-06 14:32 . 2009-03-24 14:47 38496 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2009-04-06 14:32 . 2009-03-24 14:47 15504 ----a-w- c:\windows\system32\drivers\mbam.sys
    2009-04-02 09:34 . 2009-04-02 09:33 1878888 ----a-w- C:\install_flash_player.exe
    2009-03-31 12:54 . 2009-03-31 12:54 175504 ----a-w- C:\activescan2_en.exe
    2009-03-29 14:41 . 2009-03-29 14:41 353485 ----a-w- C:\HostsXpert.zip
    2009-03-26 15:07 . 2009-03-26 14:57 62729728 ----a-w- C:\avg_free_stf_en_85_283a1450.exe
    2009-03-25 12:41 . 2009-03-25 12:41 1339834 ----a-w- C:\MGtools.exe
    2009-03-24 15:09 . 2009-03-24 15:09 65024 ----a-r- c:\documents and settings\user user\Application Data\Microsoft\Installer\{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}\IconCDDCBBF15.exe
    2009-03-24 15:09 . 2009-03-24 15:09 18944 ----a-r- c:\documents and settings\user user\Application Data\Microsoft\Installer\{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}\IconCDDCBBF13.exe
    2009-03-06 14:22 . 2005-07-11 04:48 284160 ----a-w- c:\windows\system32\pdh.dll
    2009-03-03 13:53 . 2009-04-14 12:56 17464 ----a-w- c:\documents and settings\user user\Application Data\Mozilla\Firefox\Profiles\9h1aav5x.default\extensions\{CF40ACC5-E1BB-4aff-AC72-04C2F616BCA7}\chrome\content\getPlus_Adobe_reg.exe
    2009-03-03 13:53 . 2009-04-14 12:56 12792 ----a-w- c:\documents and settings\user user\Application Data\Mozilla\Firefox\Profiles\9h1aav5x.default\extensions\{CF40ACC5-E1BB-4aff-AC72-04C2F616BCA7}\chrome\content\getPlus_Adobe_reg_bootstrap.exe
    2009-03-03 13:53 . 2009-04-14 12:56 109420 ----a-w- c:\documents and settings\user user\Application Data\Mozilla\Firefox\Profiles\9h1aav5x.default\extensions\{CF40ACC5-E1BB-4aff-AC72-04C2F616BCA7}\plugins\np_gp.dll
    2009-03-03 00:18 . 2005-07-11 04:48 826368 ----a-w- c:\windows\system32\wininet.dll
    2008-12-21 14:21 . 2007-07-27 18:57 7590400 ----a-w- c:\program files\ica32web.msi
    2008-06-15 12:27 . 2008-06-15 12:24 59839784 ----a-w- c:\program files\iTunesSetup.exe
    2008-04-10 21:17 . 2007-11-15 18:29 1495112 ----a-w- c:\program files\install_flash_player.exe
    2007-07-22 15:59 . 2007-07-22 15:59 41384 ----a-w- c:\program files\basiccms.zip
    2007-07-22 15:43 . 2007-07-22 15:42 22312757 ----a-w- c:\program files\wamp5_1.7.2.exe
    2007-01-01 15:28 . 2007-01-01 15:27 4308596 ----a-w- c:\program files\BitTornado-0.3.17-w32install.exe
    2006-12-29 16:19 . 2006-12-29 16:20 899414 ----a-w- c:\program files\DVDDecrypter_3.5.4.0.exe
    2006-12-28 20:01 . 2006-12-28 20:51 734160 ----a-w- c:\program files\VobSub_2.23.exe
    2006-12-20 20:59 . 2006-12-20 20:57 9918872 ----a-w- c:\program files\WMEncoder.exe
    2006-12-20 20:52 . 2006-12-20 20:52 878896 ----a-w- c:\program files\WGAPluginInstall.exe
    2006-12-20 15:13 . 2006-12-20 15:13 4865728 ----a-w- c:\program files\rminstall.exe
    2006-12-19 13:14 . 2006-12-19 13:14 1035271 ----a-w- c:\program files\wrar362.exe
    2006-12-02 14:16 . 2006-12-02 14:16 1480862 ----a-w- c:\program files\aresregular196_installer.exe
    2006-12-02 14:15 . 2006-12-02 14:15 1480862 ----a-w- c:\program files\Ares.exe
    2005-02-16 11:06 . 2006-12-23 11:32 218112 ----a-w- c:\program files\HijackThis.exe
    2005-07-14 12:31 . 2005-07-14 12:31 27648 --sha-r- c:\windows\system32\AVSredirect.dll
    2005-06-26 15:32 . 2005-06-26 15:32 616448 --sha-r- c:\windows\system32\cygwin1.dll
    2005-06-21 22:37 . 2005-06-21 22:37 45568 --sha-r- c:\windows\system32\cygz.dll
    2006-05-03 09:06 . 2007-07-21 17:30 163328 --sh--r- c:\windows\system32\flvDX.dll
    2004-01-25 00:00 . 2004-01-25 00:00 70656 --sha-r- c:\windows\system32\i420vfw.dll
    2007-02-21 10:47 . 2007-07-21 17:30 31232 --sh--r- c:\windows\system32\msfDX.dll
    ((((((((((((((((((((((((((((( SnapShot_2009-05-20_10.59.20.79 )))))))))))))))))))))))))))))))))))))))))
    + 2009-05-31 15:18 . 2009-05-31 15:18 16384 c:\windows\Temp\Perflib_Perfdata_808.dat
    + 2009-05-31 15:18 . 2009-05-31 15:18 16384 c:\windows\Temp\Perflib_Perfdata_2d8.dat
    + 2005-07-11 13:01 . 2004-08-04 12:00 19429 c:\windows\system32\MsDtc\Trace\msdtcvtr.bat
    + 2008-10-23 20:45 . 2008-01-18 15:13 2247 c:\windows\ServicePackFiles\i386\tscdsbl.bat
    + 2008-10-23 20:45 . 2008-01-18 15:13 2247 c:\windows\Installer\tsclientmsitrans\tscdsbl.bat
    + 2005-07-11 16:22 . 2004-08-04 12:00 2589 c:\windows\I386\RUNW32.BAT
    + 2009-05-23 14:30 . 2009-05-23 14:30 148888 c:\windows\system32\javaws.exe
    - 2009-04-12 12:49 . 2009-04-12 12:49 148888 c:\windows\system32\javaws.exe
    + 2009-05-23 14:30 . 2009-05-23 14:30 144792 c:\windows\system32\javaw.exe
    - 2009-04-12 12:49 . 2009-04-12 12:49 144792 c:\windows\system32\javaw.exe
    - 2009-04-12 12:49 . 2009-04-12 12:49 144792 c:\windows\system32\java.exe
    + 2009-05-23 14:30 . 2009-05-23 14:30 144792 c:\windows\system32\java.exe
    "ctfmon.exe "= "c:\windows\system32\ctfmon.exe" [2008-04-14 15360]
    "Apoint "= "c:\program files\Apoint\Apoint.exe" [2003-11-07 114688]
    "SonyPowerCfg "= "c:\program files\Sony\VAIO Power Management\SPMgr.exe" [2005-05-15 184320]
    "ISBMgr.exe "= "c:\program files\Sony\ISB Utility\ISBMgr.exe" [2004-02-20 32768]
    "VAIO Update 2 "= "c:\program files\Sony\VAIO Update 2\VAIOUpdt.exe" [2005-01-14 151552]
    "ccApp "= "c:\program files\Common Files\Symantec Shared\ccApp.exe" [2008-01-08 49512]
    "Symantec NetDriver Monitor "= "c:\progra~1\SYMNET~1\SNDMon.exe" [2007-10-18 100056]
    "SsAAD.exe "= "c:\progra~1\Sony\SONICS~1\SsAAD.exe" [2005-06-03 81920]
    "NvCplDaemon "= "c:\windows\system32\nvcpl.dll" [2005-06-09 6746112]
    "LXCCCATS "= "c:\windows\System32\spool\DRIVERS\W32X86\3\LXCCtime.dll" [2005-07-20 73728]
    "FaxCenterServer "= "c:\program files\Lexmark Fax Solutions\fm3032.exe" [2005-07-12 299008]
    "SunJavaUpdateSched "= "c:\program files\Java\jre6\bin\jusched.exe" [2009-05-23 148888]
    "Mouse Suite 98 Daemon "= "ICO.EXE" - c:\windows\system32\ico.exe [2002-03-14 45056]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
    "CTFMON.EXE "= "c:\windows\system32\CTFMON.EXE" [2008-04-14 15360]
    [hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
    "{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} "= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 77824]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\!SASWinLogon]
    2008-12-22 12:05 356352 ----a-w- c:\program files\SUPERAntiSpyware\SASWINLO.dll
    HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\drivers32
    "aux2 "=
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WinDefend]
    @= "Service "
    [HKEY_LOCAL_MACHINE\software\microsoft\security center]
    "AntiVirusDisableNotify "=dword:00000001
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecAntiVirus]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecFirewall]
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
    "EnableFirewall "= 0 (0x0)
    R0 pavboot;pavboot;c:\windows\system32\drivers\pavboot.sys [31/03/2009 13:56 28544]
    R1 PrivateDisk;PrivateDisk;c:\windows\system32\drivers\privatediskm.sys [06/07/2004 14:07 45627]
    R1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\sasdifsv.sys [23/03/2009 15:07 9968]
    R1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.SYS [23/03/2009 15:07 72944]
    R2 AdobeActiveFileMonitor;Adobe Active File Monitor;c:\program files\Adobe\Photoshop Elements 3.0\PhotoshopElementsFileAgent.exe [04/10/2004 04:47 98304]
    R2 MSSQL$VAIO_VEDB;MSSQL$VAIO_VEDB;c:\program files\Microsoft SQL Server\MSSQL$VAIO_VEDB\Binn\sqlservr.exe -sVAIO_VEDB --> c:\program files\Microsoft SQL Server\MSSQL$VAIO_VEDB\Binn\sqlservr.exe -sVAIO_VEDB [?]
    R2 PhotoshopElementsDeviceConnect;Photoshop Elements Device Connect;c:\program files\Adobe\Photoshop Elements 3.0\PhotoshopElementsDeviceConnect.exe [04/10/2004 03:40 118784]
    R2 WinDefend;Windows Defender;c:\program files\Windows Defender\MsMpEng.exe [03/11/2006 20:19 13592]
    S3 getPlus(R) Helper;getPlus(R) Helper;c:\program files\NOS\bin\getPlus_HelperSvc.exe [14/04/2009 13:57 33176]
    S3 SASENUM;SASENUM;c:\program files\SUPERAntiSpyware\SASENUM.SYS [23/03/2009 15:07 7408]
    S3 SQLAgent$VAIO_VEDB;SQLAgent$VAIO_VEDB;c:\program files\Microsoft SQL Server\MSSQL$VAIO_VEDB\Binn\sqlagent.EXE -i VAIO_VEDB --> c:\program files\Microsoft SQL Server\MSSQL$VAIO_VEDB\Binn\sqlagent.EXE -i VAIO_VEDB [?]
    2009-05-31 c:\windows\Tasks\MP Scheduled Scan.job
    - c:\program files\Windows Defender\MpCmdRun.exe [2006-11-03 19:20]
    2009-05-22 c:\windows\Tasks\Norton AntiVirus - Scan my computer - user user.job
    - c:\progra~1\NORTON~1\NORTON~1\Navw32.exe [2005-03-25 13:47]
    2009-05-30 c:\windows\Tasks\Symantec NetDetect.job
    - c:\program files\Symantec\LiveUpdate\NDETECT.EXE [2005-07-11 11:24]
    IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~4\OFFICE11\EXCEL.EXE/3000
    FF - ProfilePath - c:\documents and settings\user user\Application Data\Mozilla\Firefox\Profiles\9h1aav5x.default\
    FF - plugin: c:\documents and settings\user user\Application Data\Mozilla\Firefox\Profiles\9h1aav5x.default\extensions\npfax@microgaming.co.uk\platform\WINNT_x86-msvc\plugins\npfax.dll
    Rootkit scan 2009-05-31 16:42
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    HKLM\Software\Microsoft\Windows\CurrentVersion\Run
    LXCCCATS = rundll32 c:\windows\System32\spool\DRIVERS\W32X86\3\LXCCtime.dll,_RunDLLEntry@16???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    [HKEY_LOCAL_MACHINE\software\Adobe\Premiere Std\7.0\DefaultPreset]
    @DACL=(02 0000)
    @SACL=
    @= "c:\\Program Files\\Adobe\\Premiere Standard\\Settings\\DV - NTSC\\Standard 48kHz.prpreset "
    [HKEY_LOCAL_MACHINE\software\Adobe\Premiere Std\7.0\Help]
    @DACL=(02 0000)
    @SACL=
    "AdobeMediaEncoder "= "c:\\Program Files\\Adobe\\Premiere Standard\\Help\\1_0_0_0.html "
    "Contents "= "c:\\Program Files\\Adobe\\Premiere Standard\\Help\\1_0_0_0.html "
    "ExportToDVD "= "c:\\Program Files\\Adobe\\Premiere Standard\\Help\\1_13_2_0.html "
    "HowToUse "= "c:\\Program Files\\Adobe\\Premiere Standard\\Help\\0_0_0_0.html "
    "Keyboard "= "c:\\Program Files\\Adobe\\Premiere Standard\\Help\\1_4_15_0.html "
    "Search "= "c:\\Program Files\\Adobe\\Premiere Standard\\Help\\search.html "
    "Support "= "http://www.adobe.com/support/products/premiere.html "
    - - - - - - - > 'winlogon.exe'(896)
    Completion time: 2009-05-31 16:46
    ComboFix-quarantined-files.txt 2009-05-31 15:46
    ComboFix2.txt 2009-05-24 21:39
    ComboFix3.txt 2009-05-21 10:01
    ComboFix4.txt 2009-05-20 22:53
    ComboFix5.txt 2009-05-31 15:34
    Pre-Run: 12,460,593,152 bytes free
    Post-Run: 12,448,034,816 bytes free
    205 --- E O F --- 2009-05-30 11:24
    HJT Log
    Logfile of HijackThis v1.99.1
    Scan saved at 16:50:24, on 31/05/2009
    MSIE: Internet Explorer v7.00 (7.00.6000.16827)
    C:\WINDOWS\explorer.exe
    C:\Program Files\HijackThis.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.co.uk/
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
    O2 - BHO: Norton Internet Security - {9ECB9560-04F9-4bbc-943D-298DDF1699E1} - C:\Program Files\Common Files\Symantec Shared\AdBlocking\NISShExt.dll
    O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
    O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    O3 - Toolbar: Norton Internet Security - {0B53EAC3-8D69-4b9e-9B19-A37C9A5676A7} - C:\Program Files\Common Files\Symantec Shared\AdBlocking\NISShExt.dll
    O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
    O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - (no file)
    O4 - HKLM\..\Run: [Apoint] C:\Program Files\Apoint\Apoint.exe
    O4 - HKLM\..\Run: [Mouse Suite 98 Daemon] ICO.EXE
    O4 - HKLM\..\Run: [SonyPowerCfg] C:\Program Files\Sony\VAIO Power Management\SPMgr.exe
    O4 - HKLM\..\Run: [ISBMgr.exe] C:\Program Files\Sony\ISB Utility\ISBMgr.exe
    O4 - HKLM\..\Run: [VAIO Update 2] "C:\Program Files\Sony\VAIO Update 2\VAIOUpdt.exe" /Stationary
    O4 - HKLM\..\Run: [Symantec NetDriver Monitor] C:\PROGRA~1\SYMNET~1\SNDMon.exe /Consumer
    O4 - HKLM\..\Run: [SsAAD.exe] C:\PROGRA~1\Sony\SONICS~1\SsAAD.exe
    O4 - HKLM\..\Run: [NvCplDaemon] //~rundll32.exe c:\windows\system32\nvcpl.dll,nvstartup
    O4 - HKLM\..\Run: [LXCCCATS] rundll32 C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\LXCCtime.dll,_RunDLLEntry@16
    O4 - HKLM\..\Run: [FaxCenterServer] "C:\Program Files\Lexmark Fax Solutions\fm3032.exe" /s
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe "
    O8 - Extra context menu item: &Translate English Word - res://c:\program files\google\GoogleToolbar2.dll/cmwordtrans.html
    O8 - Extra context menu item: Backward Links - res://c:\program files\google\GoogleToolbar2.dll/cmbacklinks.html
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~4\OFFICE11\EXCEL.EXE/3000
    O8 - Extra context menu item: Similar Pages - res://c:\program files\google\GoogleToolbar2.dll/cmsimilar.html
    O8 - Extra context menu item: Translate Page into English - res://c:\program files\google\GoogleToolbar2.dll/cmtrans.html
    O10 - Unknown file in Winsock LSP: c:\program files\bonjour\mdnsnsp.dll
    O11 - Options group: [TABS] Tabbed Browsing
    O14 - IERESET.INF: START_PAGE_URL=http://www.club-vaio.com/en/
    O15 - Trusted Zone: *.sony-europe.com
    O15 - Trusted Zone: *.sonystyle-europe.com
    O15 - Trusted Zone: *.vaio-link.com
    O16 - DPF: {00B71CFB-6864-4346-A978-C0A14556272C} (Checkers Class) - http://messenger.zone.msn.com/binary/msgrchkr.cab31267.cab
    O16 - DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} (Facebook Photo Uploader 5) - http://upload.facebook.com/controls/FacebookPhotoUploader5.cab
    O16 - DPF: {2D8ED06D-3C30-438B-96AE-4D110FDC1FB8} (ActiveScan 2.0 Installer Class) - http://acs.pandasoftware.com/activescan/cabs/as2stubie.cab
    O16 - DPF: {8D9563A9-8D5F-459B-87F2-BA842255CB9A} (Whale Client Components) - https://myconnect.bbc.co.uk/InternalSite/WhlCompMgr.cab
    O16 - DPF: {8E0D4DE5-3180-4024-A327-4DFAD1796A8D} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsClient.cab31267.cab
    O16 - DPF: {9A9307A0-7DA4-4DAF-B042-5009F29E09E1} (ActiveScan Installer Class) - http://acs.pandasoftware.com/activescan/as5free/asinst.cab
    O16 - DPF: {F6BF0D00-0B2A-4A75-BF7B-F385591623AF} (Solitaire Showdown Class) - http://messenger.zone.msn.com/binary/SolitaireShowdown.cab31267.cab
    O16 - DPF: {F7EDBBEA-1AD2-4EBF-AA07-D453CC29EE65} (Flash Casino Helper Control) - https://plugins.valueactive.eu/flashax/iefax.cab
    O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
    O20 - Winlogon Notify: igfxcui - C:\WINDOWS\SYSTEM32\igfxdev.dll
    O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\SYSTEM32\WgaLogon.dll
    O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
    O23 - Service: Adobe Active File Monitor (AdobeActiveFileMonitor) - Unknown owner - C:\Program Files\Adobe\Photoshop Elements 3.0\PhotoshopElementsFileAgent.exe
    O23 - Service: Apple Mobile Device - Apple, Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
    O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
    O23 - Service: Symantec Network Proxy (ccProxy) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
    O23 - Service: Symantec Password Validation (ccPwdSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccPwdSvc.exe
    O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
    O23 - Service: EvtEng - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
    O23 - Service: getPlus(R) Helper - NOS Microsystems Ltd. - C:\Program Files\NOS\bin\getPlus_HelperSvc.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
    O23 - Service: Image Converter video recording monitor for VAIO Entertainment - Sony Corporation - C:\Program Files\Sony\Image Converter 2\IcVzMon.exe
    O23 - Service: iPod Service - Apple Inc. - C:\iPod\bin\iPodService.exe
    O23 - Service: ISSvc (ISSVC) - Symantec Corporation - C:\Program Files\Norton Internet Security\ISSVC.exe
    O23 - Service: Java Quick Starter (JavaQuickStarterService) - Unknown owner - C:\Program Files\Java\jre6\bin\jqs.exe" -service -config "C:\Program Files\Java\jre6\lib\deploy\jqs\jqs.conf (file missing)
    O23 - Service: lxcc_device - Lexmark International, Inc. - C:\WINDOWS\system32\lxcccoms.exe
    O23 - Service: MSCSPTISRV - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\MSCSPTISRV.exe
    O23 - Service: Norton AntiVirus Auto-Protect Service (navapsvc) - Symantec Corporation - C:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
    O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
    O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
    O23 - Service: PACSPTISVR - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\PACSPTISVR.exe
    O23 - Service: Photoshop Elements Device Connect (PhotoshopElementsDeviceConnect) - Unknown owner - C:\Program Files\Adobe\Photoshop Elements 3.0\PhotoshopElementsDeviceConnect.exe
    O23 - Service: RegSrvc - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
    O23 - Service: Spectrum24 Event Monitor (S24EventMonitor) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
    O23 - Service: SAVScan - Symantec Corporation - C:\Program Files\Norton Internet Security\Norton AntiVirus\SAVScan.exe
    O23 - Service: ScriptBlocking Service (SBService) - Symantec Corporation - C:\PROGRA~1\COMMON~1\SYMANT~1\SCRIPT~1\SBServ.exe
    O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
    O23 - Service: Symantec SPBBCSvc (SPBBCSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
    O23 - Service: Sony SPTI Service (SPTISRV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\SPTISRV.exe
    O23 - Service: SonicStage SCSI Service (SSScsiSV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\SSScsiSV.exe
    O23 - Service: SymWMI Service (SymWSC) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
    O23 - Service: VAIO Entertainment TV Device Arbitration Service - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCs\VzHardwareResourceManager\VzHardwareResourceManager.exe
    O23 - Service: VAIO Event Service - Sony Corporation - C:\Program Files\Sony\VAIO Event Service\VESMgr.exe
    O23 - Service: VAIO Media Integrated Server (VAIOMediaPlatform-IntegratedServer-AppServer) - Sony Corporation - C:\Program Files\Sony\VAIO Media Integrated Server\VMISrv.exe
    O23 - Service: VAIO Media Integrated Server (HTTP) (VAIOMediaPlatform-IntegratedServer-HTTP) - Unknown owner - C:\Program Files\Sony\VAIO Media Integrated Server\Platform\SV_Httpd.exe" /Service=VAIOMediaPlatform-IntegratedServer-HTTP /RegRoot= "SOFTWARE\Sony Corporation\VAIO Media Platform\2.0" /RegExt= "Applications\IntegratedServer\HTTP (file missing)
    O23 - Service: VAIO Media Integrated Server (UPnP) (VAIOMediaPlatform-IntegratedServer-UPnP) - Sony Corporation - C:\Program Files\Sony\VAIO Media Integrated Server\Platform\UPnPFramework.exe
    O23 - Service: VAIO Media Gateway Server (VAIOMediaPlatform-Mobile-Gateway) - Unknown owner - C:\Program Files\Sony\VAIO Media Integrated Server\Platform\VmGateway.exe" /Service=VAIOMediaPlatform-Mobile-Gateway /RegRoot= "SOFTWARE\Sony Corporation\VAIO Media Platform\2.0" /RegExt= "\Addons\Packages\Mobile\Gateway" /DisplayName= "VAIO Media Gateway Server (file missing)
    O23 - Service: VAIO Entertainment UPnP Client Adapter (Vcsw) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VCSW\VCSW.exe
    O23 - Service: VAIO Entertainment Database Service (VzCdbSvc) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzCdbSvc.exe
    O23 - Service: VAIO Entertainment File Import Service (VzFw) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzFw.exe
  5. 2009/05/31
    You used an outdated HJT version, but I don't see any issues in Combofix log, so you'll need to re-post your problem at Windows section.
    Before you go there...
    Uninstall Combofix:
    Go Start > Run
    Type in:
    combofix /u
    Note the space between the "combofix" and the "/u "
    Restart computer.
    I'm going to mark this thread as resolved.
