VCOM System Suite 4
Discussion in 'Other PC Software' started by BillyBob, 2003/06/20.
  1. 2003/06/20
    BillyBob Inactive Thread Starter
    I have this installed on Windows XP Pro.
    I have been deliberately running various Options from it and so far have seen no bad results.
    :) Of cousre only AFTER making sure I have a recent Restore Point. :)
    I am just looking for any imput from anyone that may have used it and if any problems arose from its use.
    I will say one thing though. It seems to have Norton beat all ways for Sunday, Monday and the rest of the week.
    I have not used the AV or Firewall from it as AVG and Kerio seem to be doing fine.
    Has anybody used either if these items ?
    BillyBob
  2. 2003/06/22
    HHHMMMM !!!
    I guess either no one is using it or no problems have arisen. :D
    BB
    Or nobody's heard of it :D - including me.
  5. 2003/06/22
    mflynn
    mflynn Inactive
    Used to be called Nut& Bolts.
    BB don't install all that crashguard **** etc. Same as principle as Norton Crashguard.
    I have heard somewhere that some part of this Suite takes over or ties itself to the Winsock. Not such a good thing to do!
    Mike
  6. 2003/06/22
    Hello Mike.
    I had that part already figured out.
    HUH OH !!!!!
    .I have heard that part of this Suite takes over or ties itself to the Winsock
    Already a question here. Something has changed.
    But that is the kind of info that I am looking for.
    But so far I see it as doing nothing any better so I have a strong feeling that it may disapear before I do get my backside in trouble.
    :) I do not need any help to do that. :) I can do just fine all by myself.
    Thanks folks.
  7. 2003/06/22
    Abraxas
    Abraxas Inactive
    Been using V-COM for a year with no problems. There are certainly more features than I use. I don't use the system backup or reg cleaner, for example.
    But the AV seems much less intrusive and uses less CPU than Norton.
  8. 2003/06/22
    Nuts & Bolts I had heard of - thanks Mike
  9. 2003/06/22
    Abraxas
    Abraxas Inactive
    Apparently it did ( or I told it to ) get into my system somewhere.
    :( Or I used a not so compatable part of it. :(
    I was having hiccups where I should not have.
    Unistalled VCOM and hiccups are gone.
    BTW. I have been using PowerDesk ( now from VCOM ) for years and no problems with it at all.
    BillyBob
