vbs psyme
Discussion in 'Security and Privacy' started by blingy, 2004/08/25.
  1. 2004/08/25
    blingy
    blingy Inactive Thread Starter
    how the hell do you remove this?
    i ran mcafee and its quarantined but my web still gets redirected to ads for casinos and debt management etc..its bloosy annoying. how do i get rid of it!??
    thanks in advance!
  2. 2004/08/25
    If you are with Windows ME/XP, you have to disable System Restore, before running McAffee.
    noahdfear
    noahdfear Inactive
    Start with downloading the latest versions of Spybot and Ad-aware, install, and immediately check for updates. Run Spybot and fix everything it finds and prechecks. Run Ad-aware in full scan mode and delete all it finds. Reboot and if the problem persists, download HijackThis.exe from here. Save it to a permanent folder (I create a new folder in C:\ named HJT). Open and hit scan, then save log. Once it is saved it will open in notepad. Select all from the edit button, copy and paste the results here. Don't fix anything with it yet!
  5. 2004/08/25
    blingy
    Thanks, i've done all except hijack this, i'm going to try move on boot as well.
    I also have the CHM Wallon.A worm as a result i think...are these bad? how do i get rid of teh second?
  6. 2004/08/25
    blingy
    heres my hijack this log
    Logfile of HijackThis v1.97.7
    Scan saved at 8:41:23 PM, on 8/25/2004
    Platform: Windows XP SP1 (WinNT 5.01.2600)
    MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
    C:\WINDOWS\System32\rmctrl.exe
    C:\PROGRA~1\mcafee.com\vso\mcvsshld.exe
    C:\PROGRA~1\mcafee.com\agent\mcagent.exe
    c:\progra~1\mcafee.com\vso\mcvsescn.exe
    C:\Program Files\QuickTime\qttask.exe
    C:\WINDOWS\System32\RUNDLL32.EXE
    C:\Program Files\WinZip\WZQKPICK.EXE
    C:\WINDOWS\System32\devldr32.exe
    C:\Program Files\Executive Software\Diskeeper Home Edition\DKService.exe
    c:\PROGRA~1\mcafee.com\vso\mcvsrte.exe
    C:\WINDOWS\System32\nvsvc32.exe
    c:\PROGRA~1\mcafee.com\vso\mcshield.exe
    C:\Documents and Settings\mw\My Documents\HiJACK\HijackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer,SearchURL = http://www.oborot.com/search.htm
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.oborot.com/fast-find.htm
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch = http://www.oborot.com/search.htm
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://www.oborot.com/search.htm
    O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Reader\ActiveX\AcroIEHelper.ocx
    O2 - BHO: (no name) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar1.dll
    O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
    O3 - Toolbar: McAfee VirusScan - {BA52B914-B692-46c4-B683-905236F6F655} - c:\progra~1\mcafee.com\vso\mcvsshl.dll
    O3 - Toolbar: (no name) - {2CDE1A7D-A478-4291-BF31-E1B4C16F92EB} - (no file)
    O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar1.dll
    O4 - HKLM\..\Run: [RemoteControl] C:\WINDOWS\System32\rmctrl.exe
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartup
    O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
    O4 - HKLM\..\Run: [VSOCheckTask] "c:\PROGRA~1\mcafee.com\vso\mcmnhdlr.exe" /checktask
    O4 - HKLM\..\Run: [VirusScan Online] "c:\PROGRA~1\mcafee.com\vso\mcvsshld.exe "
    O4 - HKLM\..\Run: [MCAgentExe] c:\PROGRA~1\mcafee.com\agent\mcagent.exe
    O4 - HKLM\..\Run: [MCUpdateExe] C:\PROGRA~1\McAfee.com\Agent\McUpdate.exe
    O4 - HKLM\..\Run: [xdkcimsk] C:\WINDOWS\System32\wmwlnhq.exe
    O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\System32\NvMcTray.dll,NvTaskbarInit
    O4 - HKLM\..\RunOnce: [DELDIR0.EXE] "C:\DOCUME~1\MARTIN~1\LOCALS~1\Temp\DELDIR0.EXE" "C:\Program Files\McAfee\McAfee Shared Components\Guardian\ "
    O4 - Startup: Drempels Desktop.lnk = C:\WINDOWS\drempels.exe
    O4 - Global Startup: WinZip Quick Pick.lnk = C:\Program Files\WinZip\WZQKPICK.EXE
    O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
    O8 - Extra context menu item: &Google Search - res://c:\program files\google\GoogleToolbar1.dll/cmsearch.html
    O8 - Extra context menu item: Backward Links - res://c:\program files\google\GoogleToolbar1.dll/cmbacklinks.html
    O8 - Extra context menu item: Cached Snapshot of Page - res://c:\program files\google\GoogleToolbar1.dll/cmcache.html
    O8 - Extra context menu item: Similar Pages - res://c:\program files\google\GoogleToolbar1.dll/cmsimilar.html
    O8 - Extra context menu item: Translate into English - res://c:\program files\google\GoogleToolbar1.dll/cmtrans.html
    O9 - Extra 'Tools' menuitem: Sun Java Console (HKLM)
    O9 - Extra button: Messenger (HKLM)
    O9 - Extra 'Tools' menuitem: Messenger (HKLM)
    O16 - DPF: ppctlcab - http://www.pestscan.com/scanner/ppctlcab.cab
    O16 - DPF: {0000000A-0000-0010-8000-00AA00389B71} - http://download.microsoft.com/download/d/4/4/d446e8a9-3a86-4b59-bb19-f5bd11b40367/wmavax.CAB
    O16 - DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} (QuickTime Object) - http://www.apple.com/qtactivex/qtplugin.cab
    O16 - DPF: {2FC9A21E-2069-4E47-8235-36318989DB13} (PPSDKActiveXScanner.MainScreen) - http://www.pestscan.com/scanner/axscanner.cab
    O16 - DPF: {30528230-99F7-4BB4-88D8-FA1D4F56A2AB} (YInstStarter Class) - http://download.yahoo.com/dl/installs/yinst0309.cab
    O16 - DPF: {33564D57-0000-0010-8000-00AA00389B71} - http://download.microsoft.com/download/F/6/E/F6E491A6-77E1-4E20-9F5F-94901338C922/wmv9VCM.CAB
    O16 - DPF: {4E888414-DB8F-11D1-9CD9-00C04F98436A} (Microsoft.WinRep) - https://webresponse.one.microsoft.com/oas/ActiveX/winrep.cab
    O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} (HouseCall Control) - http://a840.g.akamai.net/7/840/537/2004061001/housecall.trendmicro.com/housecall/xscan53.cab
    O16 - DPF: {9A9307A0-7DA4-4DAF-B042-5009F29E09E1} (ActiveScan Installer Class) - http://www.pandasoftware.com/activescan/as5/asinst.cab
    O16 - DPF: {9F1C11AA-197B-4942-BA54-47A8489BB47F} (Update Class) - http://v4.windowsupdate.microsoft.com/CAB/x86/unicode/iuctl.CAB?38148.0023148148
    O16 - DPF: {A8658086-E6AC-4957-BC8E-7D54A7E8A78D} (DoomCln Object) - http://www.microsoft.com/security/controls/DoomCln.CAB
    O16 - DPF: {A8658086-E6AC-4957-BC8E-7D54A7E8A78E} (SassCln Object) - http://www.microsoft.com/security/controls/Sasser/20/SassCln.CAB
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
    O16 - DPF: {F58E1CEF-A068-4C15-BA5E-587CAF3EE8C6} (MSN Chat Control 4.5) - http://chat.msn.com/bin/msnchat45.cab
  7. 2004/08/25
    blingy
    Now, from your HT log, I can see, you are with XP.
    No program will pull a miracle for you, unless you turn your "System Restore" off to remove that "bad guy ".
    According to
    McAffee site, you should have no problem to remove a pest, once you turn "System Restore" off.
    If not off:
    "This means that an infected file could be stored there as a backup file, and VirusScan will be unable to delete these files. "
    Very same goes for HT. You have bad entries:
    which keep hijacking your browser, but if you won't turn off your "System Restore" while fixing above with HT, they'll be back.
  8. 2004/08/25
    noahdfear
    noahdfear Inactive
    Download CWShredder.exe from the HijackThis link. Save it to the desktop. Close all other windows and click fix. Open C:\Windows\System32 and delete the wmwlnhq.exe file. Reboot, scan again with HijackThis and post a new log. Also recommend you scan your PC with RAV. Check the box to autoclean. If any files are infected and uncleanable, click the report button then copy and paste it here.
  9. 2004/08/26
    It would be a good idea to update Hijackthis before you scan and post the new log. v1.98.x is available.
    #8
