Utilising both CABLE and ADSL at same time!?
Discussion in 'Legacy Windows' started by jonny, 2002/04/26.
  1. 2002/04/26
    jonny
    jonny Inactive Thread Starter
    Hi, i have broadband cable and adsl , is it possible to utilise both at the same time? Almost like the dual isdn service?
    Ive heard you can merge to internet connections but im not sure..
    any help would be much appreciated.
    regards
    jon
  2. 2002/04/27
    obenton
    obenton Inactive
    As a practical matter, no. The packets will flow through the default gateway that is listed in your machine's routing table, either the DSL or cable, whichever you select. You could manually edit the routing table to send some IP addresses through DSL and the rest through cable, but this is hardly practical. There is, I understand, load balancing hardware and utilities that are used by large networks, but it's very expensive.
    Dorfmann
    Dorfmann Inactive
    obenton
    obenton Inactive
    Prices are coming down - only $400.
