using wlan on laptop
Discussion in 'Networking (Hardware & Software)' started by maxmangion, 2009/10/31.
  1. 2009/10/31
    maxmangion
    maxmangion Inactive Thread Starter
    Hi
    I have an MSI laptop which has an icon to switch on/off the wlan feature. When I switch it on a yellow/green light indicates on the front panel that the feature is turned on. I have win xp sp 2 installed. Now where should I go to check the available networks in my area. On my desktop pc i go to Start -> Connect To and choose Wireless Network Connections, however, on my laptop this option is either not available or not visible because on the ConnectTo menu I only get Show All Connections.
    Any ideas please how can i connect my laptop to my wireless network.
    Thank you.
  2. 2009/11/01
    notzofram
    notzofram Inactive
    and then
    I will assume you are wisely using XP (edit: which is handy because you are)
    if win7 (aka vista) then SOL on so many levels
    open your my computer
    click up
    right click: my network places
    click properties
    double click your wlan adapter
    click properties:
    tick these two boxes:
    http://img262.imageshack.us/img262/9291/091031eatmorecandy.png
    click ok enough times
    IFF wlan is powered
    right click wlan icon in tray (area near clock)
    something available wireless something something
    and voila
